Maxing out mass air eeven with mafia
MAF.i.a Support
racerbrad1
Post by racerbrad1 »
Im trying to get some help because we tried sct numerous times but had no luck.I have procharged 96 gt sctba2400 new maf.The meter was maxing out and even with the mafia it still would max out at 5500 rpm and stop flowing is there something that was done wrong with the mafia?
RE: Maxing out mass air eeven with mafia
What setting was used on the Mafia?
I believe that SCT offers an even larger MAF, the 2800, in an effort to eliminate this issue, but we tend to like the 90mm Lightning unit.
LightningMike03
Post by LightningMike03 »
Hey MikeL, correct me if I'm wrong, but when going to a larger MAF doesn't the A/F lean out? (slower air flow = less fuel?). Kind of the same thing the MAF.i.a does when extending the voltage range?
LightningMike03 wrote:Hey MikeL, correct me if I'm wrong, but when going to a larger MAF doesn't the A/F lean out? (slower air flow = less fuel?). Kind of the same thing the MAF.i.a does when extending the voltage range?
In theory, if no other changes are made in the tune to compensate, it would cause a lean condition.
That is why we like the factory MAFs as they have at least repeatable curves.
dynometer
Post by dynometer »
how much HP is it generating right now- the 2400 should support quite a little- is this draw through or blow thru?
stitched101
Post by stitched101 »
so without correct dyno tuning you will run lean but when set properly it will fix my lean condition im having??? i have a 99 lightning running approx 15-16# boost single blade tb cold air kit msd ignition diablo preditor tune and on the dyno it started going lean at about 4200rpm af ratio was around 14-1 at 5200 at 400rwhp and 510lbs tq any suggestions
Best suggestion, you need a custom tune, period.
You are making more boost than those tunes were designed for, thus resulting in a lean condition.
Return to “MAF.i.a”
