No problem..happy to help!Jfleming41 wrote:Don, thank you for all of your hard work in getting this to us. I have only used the 100hp tune very nice throttle response. I put 400mi on the truck and I am averaging 17.6 mpg so far. I will use the tow tune over the weekend towing the boat 7500lb and let you know how that goes.
Thanks again
u7165 update progress..
Don
2002 WS6
2002 WS6
endlesstuber
Hey Don,
I sent you my file did you get it.
Ed
Ed
Ed@X&M Hot Rods
Mt. Pleasant, Mi 48858
Mobile Dynojet 248c
(989)430-9597
XMHOTRODS.COM
Mobile Dynojet 248c
(989)430-9597
XMHOTRODS.COM
Hey Don, Enjoy the weekend. Anytime next week will work. Thanks for digging into it.
Ed@X&M Hot Rods
Mobile Dynojet 248c
(989)430-9597
XMHOTRODS.COM
Mobile Dynojet 248c
(989)430-9597
XMHOTRODS.COM
Thanks Don I will be trying it out friday going to a car show with the dyno. I had a problem under towing with bucking using the 60hp tune hopefully this will fix that to. Thanks I will let you know after this weekend.
Ed@X&M Hot Rods
Mobile Dynojet 248c
(989)430-9597
XMHOTRODS.COM
Mobile Dynojet 248c
(989)430-9597
XMHOTRODS.COM
What are your thoughts about the newest tunes from ford as related to power? I have been thinking about taking it in and getting it updated to prevent FICM damage due to the inductive heating method in use with VXCF5H5. Also been considering getting the FICM programmed with a hybrid program that has the latest inductive heating method and broader FICM timing like in early 2003. Supposedly this is the best of both worlds. Any thoughts?
from a tuning stand point, the new vxcf7 put down more power then the other cal ids stock. Its also what i primarily focused on when i did these tunes. My only complaint with the cal id is lag down low, but i believe i can fix that in the tune, seems to be timing related. Older cal ids ran the timing retarded quite a bit more down low then the vcxf7 stuff, which is turn created more heat and i believe spun the turbo a little quicker giving you a little more stand still/pedal down "umphf". I would suggest upgrading, its not a bad cal by any means
Don
2002 WS6
2002 WS6
- Jfleming41
Don, I used the 60hp tune to tow a 7500lb boat through the mountains at 80+ outside air, the EGT seem about 80deg F higher then they use to; but still only hit the 1250 mark a couple of times, fuel mileage was down about 1.5 gpm to 14.2. I have yet to use the tow tune, I have a trip planned in a few weeks with the 13K lb fifth-wheel over the mountains, I will let you know how that goes. I am still getting right around 17.5 using the 100hp tune as a daily driver.SCGt94 wrote:from a tuning stand point, the new vxcf7 put down more power then the other cal ids stock. Its also what i primarily focused on when i did these tunes. My only complaint with the cal id is lag down low, but i believe i can fix that in the tune, seems to be timing related. Older cal ids ran the timing retarded quite a bit more down low then the vcxf7 stuff, which is turn created more heat and i believe spun the turbo a little quicker giving you a little more stand still/pedal down "umphf". I would suggest upgrading, its not a bad cal by any means
I have a question the bucking while towing are they tied to the vxcf7 cal id? or the previous ones? I was wondering if I should run the tow tune for a while before the trip. Any thoughts?
Thanks again.
2006 CC 4x4 long box Airlockers 35x12.5 STT's, ARP headbolts,4" turbo Back S&B intake.
No I dont believe they are tied to that cal ID only, i could be wrong though. The main differences between the cal id's is the injector timing tables, hence why you could be seeing higher EGT's. I tried to customize each with its own timing tables so that I wouldn't cram a ton of timing into one cal ID and not another. Have I wrote you any custom tunes Jflem? Might wanna hit me up in and email with your ori, Ive sent a few out but haven't gotten any feedback, but since i know you will be towing, it might be worth your while.
Don
2002 WS6
2002 WS6
