Board index General Technical Support MAF.i.a will a mafia work for my ride???
MAF.i.a Support
Post Tue Jul 07, 2009 6:18 pm
i got a 94 mustang GT had 24lb injectors and matching MAF,,car now has a supercharger and i bumped the injectors to 42s,,,my question is,,can i keep the same MAF and use a MAFIA??? and if so which one do i need??? or do i need a new MAF?? or what are my options,thanx for your time!!
Post Tue Jul 07, 2009 6:28 pm
What MAF is it?
I would strongly recommend you look into a Lightning 90mm MAF and a Mafia.
561-908-0040x4
Post Tue Jul 07, 2009 7:40 pm
its a granatelli ,,i already called them to see if i can get it recalibrated but they said they dont offer a 42,,,i was debating a lightning maf,,if, i go that route which mafia do i use??? part number???thanx
Post Wed Jul 08, 2009 9:36 am
You would use the part #F7396.
No, i don't work here.
Post Wed Jul 08, 2009 11:50 am
thanx for your help!!!
Post Wed Jul 08, 2009 11:53 am
Actually, the F7396 is a harness that allows you to install a 96-newer style MAF in an older vehicle, but it is just a harness...you'd also need a F7373 Mafia to attenuate the MAF signal.
561-908-0040x4
Post Thu Jul 09, 2009 1:31 pm
i thought the f7373 was for 96+,,i have a 94,,, wouldnt i use the f7336?? or do i have to use the f7373 because im using a newer lightning maf??,,,what exactly is the f7336 for then??? says 86 to 95 vehicles,,thanx for your time...pete
Post Thu Jul 09, 2009 3:02 pm
7396 is a harness that adapts the 6 pin MAF plug to your 4 pin harness.
Then you need a Mafia, so the 7373 is needed for a 6 pin style connector which the Lightning MAF has.
561-908-0040x4
Return to MAF.i.a
