Shift kit for 4L60E
emilbrath
Shift kit for 4L60E
Post by emilbrath »
2000 Silverado
Well, in short order with the canned tune installed from the Predator (U7198 v.9r15) and adjustments made to shift firmness and time while keeping the one tm feature "on" it's apparent that the weak link in the equation is the tranny. 2-3 and 3-4 are great, quick and firm, but there's a good deal of "sponge" in the 1-2 shift and I fear putting down any rubber is beyond what I currently have; Vararam intake, BBK 1&3/4 Shorties and Gibson Supertruck exhaust. Truck bogs at WOT from a standing start. Will a shift kit, say from TCI, help rectify the shortcomings and increase durability of the 4L60? What effect would a shift kit have on the diablo settings? What other mods would you suggest in my quest to take 10,000 miles of wear off my tires in 20 feet? Waiting on computer serial cable to load logs and custom tune and will be back with numbers when I get them.
08Silverado
RE: Shift kit for 4L60E
Post by 08Silverado »
You could try a corvette servo, helps out with the 1-2 shift. I did it to my truck and it was a nice improvement over stock. Plus they only cost between 15-20 bucks,and, only takes about a half hour to put in.
08 Silverado 4.8l,K&N drop in, Airraid M.I.T,Magnaflow muffler, Vette servo,Predator 93 tune
emilbrath
Post by emilbrath »
Picking up servo tomorrow. Any recommendations as to predator settings for shift parameters?
2000 silverado Z-71 ecsb 60k mi. Vararam intake, Gibson Supertruck exhaust, BBK Shorty headers, Jet Billet servo, MSD 8.5 wires, AC delco iridiums, Diablo 91 tune on U7198 v.9r14
08Silverado
If I had TCM support I probly would.
emilbrath
Post by emilbrath »
Thanks for the servo tip '08. WOW, lotta bang for the buck!
Scooter88
Post by Scooter88 »
hey emilbrath jus checking out this post..I have 04 GMC Sierra 2wd with 5.3l and was wondering how hard the servo was to put in and what it took? Definely helped huh? Part number by chance?
08Silverado
No prob man, I help when I can.
emilbrath
Post by emilbrath »
Just because it was first time and I was extremely careful it took about an hour and a half. I have a 2000 Z-71 and after removing the heat shield I found there wasn't enough space to pull the servo out as a unit. I had to remove the pistons individually, then take the shaft out. The same was true of the install, spring and washers on shaft first, then placing the shaft into the servo housing, then slipping the pistons, washers and e-clip on with the shaft in the bore. Beware the "e" clip removal and installation and the snap ring!!! A standard wunderbar was perfect for leveraging the servo cover into place to install the retaining ring. I got a billet servo aftermarket, but the GM part for my truck would have been from a '99 or 2000 'vette
Dschev1
Post by Dschev1 »
Here is a site that might answer some questions to this topic, I installed the servo in my truck and found that it made a world of difference.
http://www.gmfullsize.com/forum/showthr ... vo+install
There are two kits available one for 1-2 and another that has different pistons for 1-2 & 2-3 I believe. I only installed the one for 1-2 .
2007 Silverado
4.8 w/3.23 Gear
Volant Cold Air Intake
Vette Servo
40 Series Flow Master
7194 9r07
www.eprowebdesigns.com/DiabLew_Tune/
Scooter88
Post by Scooter88 »
Thanks for the info!
WhiteBuffalo
Post by WhiteBuffalo »
Ya, I did the servo...it adds a little grabbing power...but the 4L60E is still pretty weak.
I've been thinking about this!
http://www.finishlinetrans.com/transmissions/index.htm
WB :twisted:
05 Avalanche LT Z71 5.3 4.10, Volant CAI, Volant Ram Air Scoop, Corvette 2nd & Sonnax Super Hold 4th gear servo, KYB MonoMax.
SandMan817
Post by SandMan817 »
just read that thread and i was wondering if putting in the vette servo will eliminate that "sponginess" feeling you get when shifting from 1-2 at WOT. if my truck 1-2 shift didnt have this problem im sure i would be getting much faster 0-60 times
2002 GMC Sierra Ext Cab 5.3(LM7)
Dschev1
Post by Dschev1 »
Yes it will improve the shifting from 1-2.
It'll hold better and shift quite abit firmer..
2007 Silverado
4.8 w/3.23 Gear
Vette Servo
7194 9r07
emilbrath
Post by emilbrath »
Not to point out the obvious...but I will :wink: !! For anyone doing the servo swap...I checked out a number of sites related to the swap and one of the common threads is hasty installations without proper lubrication of the "O" rings. Lotta torn ones out there and subsequent excedrin headaches. Make sure ya use a sufficient amount of assembly lube to do the job. Don't just use trans fluid as a number of folks have tried or recommended. And if it don't go...don't force it!
chevyZ71
Post by chevyZ71 »
I have an 04 Z71 5.3 what to know want trans I have and where can i get a vette servo. thanks
Return to “Predator GM Gas”
