Hi Guys,
I just installed the 87 octane tune in my 2005 Tahoe and I wanted to turn off my toque managment. How do I do this? I do not see how to do it based off the menu options?
Turning Off Torque Management - Help
RE: Turning Off Torque Management - Help
If your model predator is a U7193 then after you select a tune to install you will be given the option to modify the tune. If you select the option to modify the tune you will be given a list of parameters that you can change and there you will find the one for torque managment. From my experience with this option the only torque managment it will disable by turning it off is the torque managment between gear shifts. If you are looking for a firmer shift I would suggest leaving the torque managment on and adjusting the partial and WOT shift pressure. Hope this helps!
Read this page regarding the adjustable parameters for the U7193 Predator:
http://www.diablosport.com/index.php?mo ... lay&pid=98
