2008 6.4 no cruise control with new 9r05 update
RE: u174 issue
Make sure your dsdl is on auto connect make sure that you click Send CROM file to tool....
Insert Clever comment here...
RE: u174 issue
Got the same issue-- file will not decompress-- dies at line 124. Predator autoconnects properly, using "send CROM file" -- had exactly the same issue yesterday with 9t05c and 9t05d files. Something is different at that point in the files between the test and released versions...
Pesky User, running 2008 6.4l PSD F450 CC LB, 5000 lb truck camper in bed, desperately searching for better fuel economy...
RE: u174 issue
Another clue, perhaps-- tried to download the 9r04 file and that also failed to decompress. 9r05 does load into the tool, but that's where I came into the discussion-- no cruise after tuning
duncan
duncan
If that's the same file you posted yesterday afternoon at 4:44 or so, it didn't decompress for me this morning ("failure at line 124," previous post), with a similar result for the other fellow who tried it at 9:34 last night. The latest crom that has worked on my truck (with cruise control OK
is 9r02.
OK-- off to the truck to warm it up and restore to factory tune. the issue I had with the earlier file was loading it into the Predator. Will advise once I get back inside and thawed out-- 33 degrees and 20 mph wind. Would that I were doing this in Delray Beach
OK, we are looking into this as I type this....
The file that was up here before was corrupted, oye. Delete the other one, try this one:
u7164-9t06a.crom
u7164-9t06a.crom
johnc <at> diablosport.com
robbydiesel
armentrout2
OK, thank you.
