Page 2 of 2
Posted: Thu Apr 02, 2009 11:50 am
by ywait
I have a 125 Zex Kit I'm installing today.
I have the NGK 2314.. but I can't get the A/F Down in the 12's..
At idle she's at A/F is 14.9 and then at WOT come down to 13.5 or so...
I'm getting 3.5 ST and 6 LT KNK with 91CAI tune
Please Help...
Posted: Thu Apr 02, 2009 12:05 pm
Have you added fuel?
If so, how much?
Posted: Thu Apr 02, 2009 12:08 pm
by ywait
no I have not yet...
How much should I start with?
Posted: Thu Apr 02, 2009 12:21 pm
by ywait
going to changes the plugs first
Posted: Thu Apr 02, 2009 12:57 pm
Wow, you may want to consider some custom tuning from a CMR dealer, as you are about to get into trouble.
You need to get the WOT A/F right before you spray it, and you also want to get rid of that KR before you consider spraying as well.
Posted: Thu Apr 02, 2009 1:45 pm
by ywait
Yes I have not installed the zek yet just changing the plugs..
Tune the knk out after new plugs... NO ????
Posted: Fri Apr 03, 2009 8:40 am
by ywait
Which is the TPS wire for output.. I installed the kit last night.. I put the resistor in line with the white wire from the zex box..
Finshed the A/F it at 13, WOT it drops to 12 and 11.. 91 CAI tune and WOT spark retard set at 6 put I have the 125 jets in place..
Which wire do I splice into The install doc says BROWN w/ ORANGE STRIPE but there isn't one on the 09 or I went color blind..
Please help
Posted: Fri Apr 03, 2009 10:06 am
by ywait
ok I've been up to long... Cleared the codes everything is good.. I had the right wire once I looked at it again after the sun came up.. I need better lighting..
Anyway thanks...
