Page 2 of 3
Re: RE: U7137 Out of Memory
Posted: Fri Nov 13, 2009 3:08 pm
by Crimson
butch1581 wrote:gw8816 wrote:I took the truck back to the original state. Re-installed 9R04, and installed 93 can tune. Hooked up to computer and backed up original and last tune written. Go back to 9R04, fixed the problem. I can only surmise that 9R05 has a bug. Atleast so much as retrieving the last file written. Hope this helps others experiencing this issue.
Where can I get 9R04?
here you go
U7137 out of Memory
Posted: Sun Nov 15, 2009 2:50 pm
by ironbyron
Mike! Tried the update that sent me but still shows has out of memory.87 and 93 Programs seem to load no problem.I know this because this 09 Hemi truck goes like it never has before.Regards, Ironbyron
RE: Re: RE: U7137 Out of Memory
Posted: Mon Nov 16, 2009 11:14 pm
by brandy16
You can get it off the downloads page on the diablo web site
Re: RE: Re: RE: U7137 Out of Memory
Posted: Tue Nov 17, 2009 6:44 pm
by butch1581
brandy16 wrote:You can get it off the downloads page on the diablo web site
If you are talking about the 9r04 download it is NOT on the download page....
I tried loading the 9R04 that was posted here and it would not let me load it on the predator...... it said it "could not be decompressed"
What gives. I am sick of this "Out of Memory" Crap.
I can't even plug into my truck with the datviewer, as soon as it tries to connect to the truck it gives me the "out of memory" has there been any progress on this issue from Diablosport, or can you at least list the 9R04 for download?
RE: Re: RE: Re: RE: U7137 Out of Memory
Posted: Tue Nov 17, 2009 11:16 pm
by hemisphere2
I also get the out of memory on my screen when trying upload my last tune written to my PC, is someone working on this?
Posted: Wed Nov 18, 2009 12:22 pm
Yes, we are looking into it.
Posted: Wed Nov 18, 2009 1:15 pm
by Crimson
butch1581 wrote:brandy16 wrote:You can get it off the downloads page on the diablo web site
It worked for me when I went back to 9r04. Hrmm... try this:
http://uploading.com/files/128e9df1/u7137-9r04.crom/
I know this forum server has trouble sometimes with files.
Posted: Wed Nov 18, 2009 5:17 pm
by butch1581
thanks for posting that again. I will try to load it when I get home this weekend. I was able to download the first one you posted no problem too, It's just when I went to load it onto the Predator, I got an error. Hopefully it will work this time. Thanks again
Posted: Thu Nov 19, 2009 3:04 pm
by white_lightning
any tuning changes/improvements in 9r05 vs 9ro4 in the U7137?
only change noted on the update page is '09 Ram tuning. if that is the only change, I see no advantage to change from 9ro4 to 9ro5 since I have an '05 Hemi Ram.
Posted: Sat Nov 21, 2009 2:14 pm
by butch1581
Crimson wrote:butch1581 wrote:brandy16 wrote:You can get it off the downloads page on the diablo web site
Thanks a ton man the 9R04 works great no more Out of Memory Crap!
Like said earlier anyone with the problem go to the 9R04! Thanks
Hopefully the next version doesn't have the issue.
Posted: Sat Nov 21, 2009 7:42 pm
by 09Laramie
FWIW- I only saw the "Out of Memory" error one time, when I was doing the DCX update. Haven't seen it since, and it's written the 87, 93, and stock tunes, modified parameters, and data logged with no errors
Re: RE: Re: RE: Re: RE: U7137 Out of Memory
Posted: Sun Nov 22, 2009 2:48 am
by butch1581
09Laramie wrote:FWIW- I only saw the "Out of Memory" error one time, when I was doing the DCX update. Haven't seen it since, and it's written the 87, 93, and stock tunes, modified parameters, and data logged with no errors
Lucky you.......I tried like 10 times and it never worked........now the 9R04 works fine and dandy....
Posted: Sun Nov 22, 2009 3:26 pm
by Crimson
butch1581 wrote:09Laramie wrote:FWIW- I only saw the "Out of Memory" error one time, when I was doing the DCX update. Haven't seen it since, and it's written the 87, 93, and stock tunes, modified parameters, and data logged with no errors
Glad I could help.
RE: Re: RE: Re: RE: Re: RE: U7137 Out of Memory
Posted: Sun Nov 22, 2009 4:40 pm
by hemisphere2
How do I switch from 9r05 to 9r04? I downloaded the file from the link posted, what do I do now?
Re: RE: Re: RE: Re: RE: Re: RE: U7137 Out of Memory
Posted: Sun Nov 22, 2009 6:41 pm
by white_lightning
hemisphere2 wrote:How do I switch from 9r05 to 9r04? I downloaded the file from the link posted, what do I do now?
use the Diablo downloader to put 9r04 back in your Predator. 9r05 will be erased & 9r04 will replace it.
you should keep CROM files in a folder on your computer and/or on a disk. makes it easy to switch back to a CROM you like better.
I have copies of 9r02, 9to3c, 9r04 & 9r05.
currently using 9r04, haven't tried 9r05 because of the bugs it has.
