U7137 Out of Memory
U7137 Out of Memory
I have a U7137. Installed 9R05 today, and tuned the truck with the 93 perf tune. Downloaded the original back-up to save. Now when trying to download the last tune written, i keep getting an "Out of Memory" message on the predator. I've tried it three times with the same results.
Anybody have any ideas on how to clear the memory?
2008 RAM 1500 QCSB
BBK Shorty's, Magnaflow Catback,
Airaid MIT, K&N Drop-in, Predator u7137,
180* Thermo, 4.10 gears w/TrakLoc LSD,
Transgo HD Shift kit, Sonnax Line Booster,
85mm Throttle Body
85mm Throttle Body
RE: U7137 Out of Memory
I havent had the chance to hook up mine to the computer yet. I have the predator updated to the 9R05. See if I have the chance today.
I got the same message yesterday. All you need to do is re-install the 93 tune again.
I just got my predator and I also got an "Out of Memory" error.
First plugged it in to my truck ('09 Ram 1500, 5.7L Hemi) and got a message saying that my vehicle needed an update. Did the DCX update, and at the end of the update, just after a bunch of key cycles, it gave me that "Out of Memory" error. Unplugged the predator when it prompted me to, turned the key off, and then I was able to download the original backup and write the 87 tune with no more errors.
Question for the Diablosport staff: Is this "Out of Memory" error something to be concerned about? Is it something that either needs to be fixed or will be fixed in a future crom release?
and a side question for anybody that knows the answer- what does DCX stand for, and what exactly does that do to the vehicle?
I took the truck back to the original state. Re-installed 9R04, and installed 93 can tune. Hooked up to computer and backed up original and last tune written. Go back to 9R04, fixed the problem. I can only surmise that 9R05 has a bug. Atleast so much as retrieving the last file written. Hope this helps others experiencing this issue.
2008 RAM 1500 QCSB
85mm Throttle Body
85mm Throttle Body
I'll look into this...
please post up a VIN and calid for those having this issue...
calid is 68059434AB (after the DCX update from a calid of 68059434AA), and PM sent with the VIN
lross78550
Original Calid was 68059437AA
Current Calid is 68059437AB
VIN # PM'ed to mikel
Lee
Lee
I had this issue as well. Can get the info tomorrow if you like.
It was during the initial Performace Tune step. The step took a good 10-15 minutes, had me turn the key off, back on, then off and back on, at which point it said out of memory. I then proceeded to put the 93 tune on, it backed up my stock and put the 93 on without error. I now have my stock tune on my PC
I'm having the same issue on 56029161AF. Attempting to datalog via PC immediately shows "Out of Memory" on the tool.
2004 5.7L Truck
Wes
2004 5.7L Truck
Wes
Re: RE: U7137 Out of Memory
Mine shows out of memeroy also
U7137x
2009 Dodge Hemi Ram
Calid 68059431AB
Vin have emailed mike
U7137x
2009 Dodge Hemi Ram
Calid 68059431AB
Where can I get 9R04?gw8816 wrote:I took the truck back to the original state. Re-installed 9R04, and installed 93 can tune. Hooked up to computer and backed up original and last tune written. Go back to 9R04, fixed the problem. I can only surmise that 9R05 has a bug. Atleast so much as retrieving the last file written. Hope this helps others experiencing this issue.
2006 Dodge Ram 5.7 Hemi
Predator
V.9r11
Custom tune from Procharger
Predator
V.9r11
