U7137 Out of Memory
gw8816
U7137 Out of Memory
Post by gw8816 »
I have a U7137. Installed 9R05 today, and tuned the truck with the 93 perf tune. Downloaded the original back-up to save. Now when trying to download the last tune written, i keep getting an "Out of Memory" message on the predator. I've tried it three times with the same results.
Anybody have any ideas on how to clear the memory?
2008 RAM 1500 QCSB
BBK Shorty's, Magnaflow Catback,
Airaid MIT, K&N Drop-in, Predator u7137,
180* Thermo, 4.10 gears w/TrakLoc LSD,
Transgo HD Shift kit, Sonnax Line Booster,
85mm Throttle Body
Crimson
RE: U7137 Out of Memory
Post by Crimson »
I havent had the chance to hook up mine to the computer yet. I have the predator updated to the 9R05. See if I have the chance today.
MGH
Post by MGH »
I got the same message yesterday. All you need to do is re-install the 93 tune again.
09Laramie
Post by 09Laramie »
I just got my predator and I also got an "Out of Memory" error.
First plugged it in to my truck ('09 Ram 1500, 5.7L Hemi) and got a message saying that my vehicle needed an update. Did the DCX update, and at the end of the update, just after a bunch of key cycles, it gave me that "Out of Memory" error. Unplugged the predator when it prompted me to, turned the key off, and then I was able to download the original backup and write the 87 tune with no more errors.
Question for the Diablosport staff: Is this "Out of Memory" error something to be concerned about? Is it something that either needs to be fixed or will be fixed in a future crom release?
and a side question for anybody that knows the answer- what does DCX stand for, and what exactly does that do to the vehicle?
concoursd
Post by concoursd »
daimler chrysler
gw8816
Post by gw8816 »
I took the truck back to the original state. Re-installed 9R04, and installed 93 can tune. Hooked up to computer and backed up original and last tune written. Go back to 9R04, fixed the problem. I can only surmise that 9R05 has a bug. Atleast so much as retrieving the last file written. Hope this helps others experiencing this issue.
2008 RAM 1500 QCSB
85mm Throttle Body
I'll look into this...
please post up a VIN and calid for those having this issue...
09Laramie
Post by 09Laramie »
calid is 68059434AB (after the DCX update from a calid of 68059434AA), and PM sent with the VIN
lross78550
Post by lross78550 »
Original Calid was 68059437AA
Current Calid is 68059437AB
VIN # PM'ed to mikel
Lee
09RamOhio
Post by 09RamOhio »
I had this issue as well. Can get the info tomorrow if you like.
It was during the initial Performace Tune step. The step took a good 10-15 minutes, had me turn the key off, back on, then off and back on, at which point it said out of memory. I then proceeded to put the 93 tune on, it backed up my stock and put the 93 on without error. I now have my stock tune on my PC :)
wes@tps
Post by wes@tps »
I'm having the same issue on 56029161AF. Attempting to datalog via PC immediately shows "Out of Memory" on the tool.
2004 5.7L Truck
Wes
ironbyron
Re: RE: U7137 Out of Memory
Post by ironbyron »
Mine shows out of memeroy also
U7137x
2009 Dodge Hemi Ram
Calid 68059431AB
Vin have emailed mike
butch1581
Post by butch1581 »
Same Issue:
Calibration ID
PCM: 56029207AK
TCM: 56029224AF
VIN: 1D7HU18276S625419
2006 Dodge Ram 5.7 Hemi
Predator
V.9r11
Custom tune from Procharger
butch1581
Post by butch1581 »
gw8816 wrote:I took the truck back to the original state. Re-installed 9R04, and installed 93 can tune. Hooked up to computer and backed up original and last tune written. Go back to 9R04, fixed the problem. I can only surmise that 9R05 has a bug. Atleast so much as retrieving the last file written. Hope this helps others experiencing this issue.
Where can I get 9R04?
Predator
V.9r11
