Page 2 of 2
RE: Dumb EGR question...
Posted: Thu Apr 08, 2010 1:01 pm
by IEATWS-6
Any new findings on the issue with the EGT's? I took a little trip with it yesterday, with a 30mph crosswind at 80mph, my EGT's were holding around 320-325 degrees. That is using the 0-1500 scale you recommended.
Posted: Sun May 23, 2010 8:12 pm
by mater
i just put a trinity on my 06 lly crew cab 4x4 and it halls balls
Posted: Mon Jun 21, 2010 10:39 pm
by honda_man_300ex
i have no idea about your egt issue other than whether it's installed infront of the turbo( ex. manifold) or post turbo(in the down pipe) you should be having alot more than that. i had an edge at one time that the probe wires would get bad after time and you had to replace the probe(wires from the juice box to the manifold) also i had an 05 lly and had your problems at wot and it got worse. i ended up putting a shim kit in the fuel pressure relief valve because it wouldn't hold enough fuel rail pressure. it could just be a fuel filter though if you got bad fuel which can be real comon in certain places
Posted: Sun Jul 04, 2010 12:22 pm
by IEATWS-6
OK, new fuel filter, egr block plate with a finger stick....WOT get 100% engine load and 28lbs of boost, but it feels like I am in 3' of sand....wont go but smokes like a locomotive. Put the stock tune back, runs pretty good, 85hp tune...junk. Downloaded the latest update for the trinity, now all I have is original back up and modified stock tune, none of the others. What did I screw up now?
Posted: Tue Jul 06, 2010 11:12 am
please email us the backup file it saved so we can add it in a new revision.
Posted: Fri Jul 09, 2010 2:21 am
by IEATWS-6
So what can I do to get the other pre-loaded tunes that were on the trinity when I got it?
Posted: Mon Jul 12, 2010 11:39 pm
by IEATWS-6
Thank you so much for all the help, Mike! Running like a Duramax again...Just ask the joker driving the powerstroke that wanted to see how well a duramax really runs;)
Posted: Tue Jul 13, 2010 9:29 am
Good to hear, enjoy!
