Page 2 of 3
RE: Re: RE: 2011 silverado e85?
Posted: Tue Nov 08, 2011 11:29 am
by mxer97
Off topic mikel, but I am trying to adjust the axle ratio on this u7194 and the base for the adjustment says 3.22 and the high is 6 and the low is 0 ..... Where is 4.10 at on that spectrum ? Thanks
Posted: Tue Nov 08, 2011 12:58 pm
it wont let you make fine adjustments?
Posted: Tue Nov 08, 2011 1:04 pm
try updating to this
Posted: Tue Nov 08, 2011 3:51 pm
by rjaro7
I have a 2010 sierra with a 5.3 flex fuel. I used the diablo tune when I was using e85. It was the fastest the truck has ever ran with no knock retard. I went from 16 mpg with 87 octane gas with the 87 octane tune to 11 mpg using e85 with the diablotune.
Posted: Tue Nov 08, 2011 4:00 pm
e85 FTW!
E85
Posted: Wed Nov 09, 2011 12:56 am
by rlkimmel
My 2010 Colorado 5.3L is flex fuel. Although I've never used it, I understand my truck would run like the proverbiale "Bat out of hell. " In all cases the milage would drop by 30 to 35% and I've heard stories about burned valves and a host of other problems with running it full time. For one thing, ethanol burns a lot faster than gasoline so the timing has to be retarded a lot and the computer won't self-adjust that much if you run gas. As far as gas goes, the higher the octane the slower (and smoother) it burns. Several racing organizations have "gone green" but bear in mind that those engines are built to last about 1,000 miles or less. The only way I'll ever use ethanol is if gas isn't available.
RE: E85
Posted: Wed Nov 09, 2011 8:17 am
by mxer97
How do I go about doing that mikel ?
RE: E85
Posted: Wed Nov 09, 2011 8:06 pm
by mxer97
Never mind lol!!! I asked that while I was half asleep lol
RE: E85
Posted: Wed Nov 09, 2011 9:34 pm
by mxer97
Still didn't work mikel ... I'm not sure what the deal is its doin the same thing as last time its just my shift points are a little lower lol
RE: E85
Posted: Thu Nov 10, 2011 11:11 am
post your backup and last tune written and ill do it for you.
RE: E85
Posted: Mon Nov 21, 2011 9:09 am
by mxer97
Hey mikel ! I'm gonna put that tune up here tonight how soon could u have it... My truck only makes the shift rpm adjustments I made when I walk it through the gears ... Not in drive... And I also need it set to 4.11 gears thanks ... Anywhere specifically u want me to send that tune too ?
RE: E85
Posted: Mon Nov 21, 2011 11:10 am
just post it here...
RE: E85
Posted: Mon Nov 21, 2011 11:12 am
post it up here in this thread...
RE: E85
Posted: Mon Nov 21, 2011 6:22 pm
by mxer97
I'll post it up about 6:15 central time
Posted: Mon Nov 21, 2011 8:26 pm
by mxer97
original
