'05 GC won't hit 5th gear/lockup until 75mph..??
johan
Post by johan »
The trans tune you posted had considerable changes done to the lockup logic, all i did in the attached tune here was set that back to stock, everything else was left as is.
This was the custom cmr tune you posted right?
tcm_ltw_001.drg
(119.22 KiB) Downloaded 175 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
ksrracer wrote:This happened on every tune loaded since I received the intune. Like I said it never happened when set back to completely stock or when the Superchips flashpaq was loaded.
but did you get any custom tunes from any CMR tuners?
ksrracer
Post by ksrracer »
johan wrote:The trans tune you posted had considerable changes done to the lockup logic, all i did in the attached tune here was set that back to stock, everything else was left as is.
Yes. That was the last tune written. As I posted earlier this happens on the canned tunes, the CMR, and with the stock trans tune on the Intune. It does not happen when the intune is removed completely and or I'm running the Superchips. It has lead me to believe its something with the Intune itself.
Why would it not hit 5th until 75+MPH and then when 0% throttle load and coasting down, it will downshift into 4th around 68mph?
ok, bu the changes in your tune were not something we do, and would cause your issue, so can you load the canned tune, reset parameters, and export that so we can see it.
ksrracer
Post by ksrracer »
You want me to load just the stock canned tcm tune? The one Johan posted or the Performance canned tune? After that tune is loaded I post the LTW again? Seems kind of futile when I've told you its happened on all of the intunes canned tunes...
well I cant fix it if we cant see it.
please do so if you can.
ksrracer
Post by ksrracer »
Ok which tune specifically would you like me to load?
the preloaded tcm perf tune
ksrracer
Post by ksrracer »
Ok, so just to clarify I would load the pre loaded tcm performance tune and then send that to you as the LTW file?
ksrracer
Post by ksrracer »
Just want to make sure I post the right file. Thank you in advance.
Yes, thats correct.
ksrracer
Post by ksrracer »
I will do that asap.
ksrracer
Post by ksrracer »
Mikel here is the canned 91 tune and perf. tcm tune LTW.
PCM_LTW.drg
(36.63 KiB) Downloaded 166 times
TCM_LTW.drg
(125.38 KiB) Downloaded 172 times
white_lightning
Post by white_lightning »
Johan, retracting post, did not mean to cause trouble. I apologize.
hope this Jeep's issue can be fixed easily.
Last edited by white_lightning on Wed Feb 15, 2012 5:57 pm, edited 2 times in total.
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
We only write calibration data, so there cant be changes outside the tune data.
The last tune written from an inTune is an actual copy of what was written to the TCM, so you can see exactly what went in.
We are investigating.
