problem with 2012 wrangler released tunes
RuffRider
Re: problem with 2012 wrangler released tunes
Post by RuffRider »
I wish I had an alt vehicle but I don't.
I don't feel safe driving it that far back to work tomorrow. It also drops the rpms hard once it hit a full stop, almost stalls...
It ran AWESOME beforehand on the perf93oct tune this morning before the lockout/ restore.
Thanks for your help Mike!
2012 JKU RUBIKONG: Far too much to list here...
RuffRider
Post by RuffRider »
Getting the code now... 2 mins.
RuffRider
Post by RuffRider »
39BC D72A 34A1 67BB 3939
ok, type this in:
RULURDLU
then, click OK.
then let the tool reboot
then select performance
it will tell you forced cal update enabled
then click ok
it will then tell you the vehicle needs an update, click OK
unplug
connect to pc
open DSDL
let it auto connect, then click the calibration updater button
once it loads to trinity, go back to Jeep, select performance, let it load cal update, and it will all be back to 100% stock.
RuffRider
Post by RuffRider »
Will do.
Will that also update the crom files so I have the correct performance files as well??
Thanks for staying late for me!!
no, once thats done, if the tool needs to be updated, let it do that.
RuffRider
Post by RuffRider »
Got it
THANKS
RuffRider
Post by RuffRider »
Must have left out something as ince I hit OK it went right to an expert menu. No performance to select from there...
RuffRider
Post by RuffRider »
I must have fatfingered the keypad on the tuner.
Here is the code from the forced menu
5C8D 5D3D 9E31 9E20 6DE4
RuffRider
Post by RuffRider »
BUMED THE FLIPPIN' Plug while getting back in the jeep & turned off the tuner. Is it Monday?
Key Code is: 6536 8483 CC86 84A7 1539
