Page 2 of 2
Re: hellp me after update stuck in recovery mode
Posted: Thu May 23, 2013 9:17 pm
by 2001cpx
How do you have resolved your problem,i have exactly the same!!!
thanks in advance
Posted: Fri May 24, 2013 8:17 pm
by 69rrbruce
Yea what was the solution.....I've got the same problem as well.
Posted: Mon May 04, 2015 3:50 am
by jwarner
gs123 wrote:Thank you all :D
problem has been resolved :drivingbad: :drivingbad: :drivingbad:
OK so no one ever got the answer?? What was the cause or more importantly what was the fix?
I have a problem with my inTune unit freezing about 3-5 seconds after the message about "....turn key to on position...."" the little circle type dial on the unit shows it is working the just stops. Unit will not respond. I have tried every combination, every option available on unit display. I have unhooked any electrical aftermarket part but still my inTune unit freezes in the same manner every time. I had no problem for a year w/ monthly, at times weekly, changes with no issues at all. I last played w/ trans shifting points and I have them to high now but can not go back. My unit even tells me there is my backup/restore tune available but when I "force restore" I still get the same freeze after the " turn key to on position" Can anyone help? I am at the point of getting my ECM/TCM flashed at the dealer just to undo all of it because no one from diablosport will respond to my 5 emails.
2007 Tahoe LT 5.3L flex fuel
Posted: Sat May 23, 2015 8:13 pm
by dguthrie66
Did you get this fixed?
Before I use my new I1000 I want to be sure it won't screw something up.
Did Customer support fix this one with phone call ?
Posted: Sat May 23, 2015 9:02 pm
by jwarner
Yes, actually the day of the post. I had to copy some files and attached then to the post and Mike "MIKEL" if you see his login name on forum, sent me back files to down load and instructions. Worked fine. Not sure what caused problem ?? But its all good now
