updating i-1000
Re: updating i-1000
I did get it to load after three attempts (diablo tune with hard shift)had to keep unplugging as it would freeze up .But at least I know its working as i can tell the power has been added now... Just having a lot of little quirks.
Re: updating i-1000
I just checked, there was duplicate records of your registration. I have activated you and your intune should be able to continue on by itself. If you have any issues please reply and I will help.
Thanks,
Daniel
Thanks,
Daniel
Re: updating i-1000
So do i need to go about trying registration again or is it done???? had a few little quirks changing to dailbo tune but it finally took and I can sure tell now ....HAPPY..HAPPY.
Re: updating i-1000
next time you runthe updater with the tool plugged in, it will download the reg file.
Re: updating i-1000
ok I'll give it a go thank much.
Re: updating i-1000
ok it did pick up an update but didn't go on to update page , but my xml file changed to registeation (1). guess i'm done with registration??
<?xml version="1.0"?>
-<tool_info> <main svn="6254" sw_rev="1r03j" full_version="InTune-1r03j 05/29/2013 01:30:58 PM"/> <registration status="1" sn="IGU3KA1-2"/> <cal_id CM2="20964291, 20964272, 20964263" CM1="24255281, 24255562, 24255559, 24255563" PCM="12653674, 12649538, 12649507, 12625892, 12620690, 12640912, 12649842, 12649812"/> <restore bc="10" vin="1GCNKPEA7DZ328608" id="0"/> <system_db vin="1r01c" dtc="1r01a" info="1r01b"/> <db pid="1r01a" tune="1r01b" mfr="DCX"/> <db pid="1r01b" tune="1r01n" mfr="FORD"/> <db pid="1r01a" tune="1r01q" mfr="GM"/> <license tuned="1" avail="1"/> <updates count="3"/> <oem tool_oem="DIABLO"/> </tool_info>
Re: updating i-1000
yup, all set.
Re: updating i-1000
wellll.... think you much for all the help, you guys are great. It has added a bit to my little mouse motor.
