Page 2 of 5
VXAP2n2 2003 6.0 u7165
Posted: Wed Dec 26, 2007 7:55 pm
by Treestand72
Can't wait untill the program is ready. Hopefully you will fix the problem. Been a customer since 2003 with this being my second programmer.
Posted: Thu Dec 27, 2007 5:08 pm
by dieseldoug
mikel wrote:dieseldoug wrote:2000 6speed manual 4x4.......7170 128k.....very bad throttle surge or "flat spot" in the go pedal......60,85,100 tunes all drive thris way ....40 hp tune is the only one that is linear but it doesn't have much nut......truck actually has more acceleration at 1/4 throttle than at 1/2 or 3/4.......not linear at all an very noticeable to all who ride or drive........fuel mileage is good and smoke is minimal ( unlike that 8r01)
Doug, are you running 7r19dz?
yes i am.......sorry
Posted: Thu Dec 27, 2007 11:56 pm
by Excursionist
I have a U7170 7r19dz, CAl ID TNAA7Y5
2002 Excursion
7.3
AFE stage 2 intake, banks high boost compressor wheel, Big Head wastegate, and Monster exhaust with power elbow.
I mention this because I am interested in custom tuning and their benefits? I get great fuel mileage from the 100 HP tune. I have recorded 22 mpg on the highway.
What can custom tuning do for me? Can I better my performance without detrimental long term effects?
Ok here are the problems,
First install of the Predator caused a theft light issue. One flash...then six flashes. then repeats that sequence. Returning the truck to stock tune did not fix the problem. The tune was from a Feb 2006 Predator and the original tune installed was the 6o HP.
Two weeks ago I had the truck to ford for some repairs.. Oil pump, new Cam position sensor.
They said the truck shouldn't even run with the theft system flashing that sequence. Somehow the theft system had been bypassed. They replaced all the system components. Still flashing.
They then tried to re-flash the PCM but said they were unable to. They said there was a program "burned into it?" and were unable to re-flash it. They said it was damaged and I had to purchase a new one.
Also, Is it possible to have the oil pressure surge too high and blow out seals? It literally blew out at the threads on the out put line. It was tuned to the latest updated 100 hp. Ford said it may have been caused by the pcm problem.
I called your support line and posed the question "what if I install a tune to the new PCM and the problem repeats itself" I am out a bit of cash already with the new PCM and Oil pump.
They assured me I would be taken care of and I trust I will be.
So
Now with the new PCM, I programmed in a tune and the Theft Light flashing has come back! The only difference this time is when I return to the original tune it goes away.
I want tuning but not a bypassed theft system, or damaged pcm's, and oil pumps and the $2,000.00 repair bills.
I called for support yesterday and the gal said Cole was gone and took my Cal ID and info and said he would call today. I received No call
so am leaving this post.
Posted: Fri Dec 28, 2007 9:58 am
Sorry, Cole had a family emergency and will be out until the 2nd.
We will have him look into this asap.
7.3 tunes
Posted: Sun Dec 30, 2007 4:24 pm
by mtwarrior
U7170 tuner for '99 7.3 Auto trans.
CalID-VHAE9J2 v.8r05
4" turbo back exhaust, AEM intake, Precision billet converter w/ shift kit.
60hp tune-Mushy shifting, searches for gears,pulls good in mid-range,flat on top.
85hp tune-throttle response right off bottom is so touchy is hard to drive, good accel. and power.
100hp tune-doesn't really do anything, 85 hp seems like more power and faster.
Issue with Ford Diesel Tool
Posted: Wed Jan 02, 2008 3:35 pm
by jginochio
Cal ID: VNAA9S4
Version: 8r05
Serial: d0009fba
Part: u7170 pstroke73
Truck 2000 Ford F250 Powerstroke Diesel 7.3L
Tow Tune and 85 HP seem fine. 100 HP feels like its back to stock tune and when its on the 60 hp tune the motor does not idle it starts up and chugs. it doesnt do this with any other tune. truck runs fine with stock tune. Also i cannot adjust shift firmness. im not given the option to like it says in the manual. My email is
[email protected]. When will the updates be sent out? Can i return the tool if its not soon?
How do I return my programmer?
Posted: Thu Jan 03, 2008 11:25 am
by iwantmorepower
I have been waiting very patiently for 7 months for a tune that works ,but as of today I still cannot use my programmer! This is a joke!I want to return this thing and get my money back . Please respond and don't just give us some line that we need to be patient because you just bought the company or you have fired the guy responsible ,step up and give us a tune that actually works or start a refund program and help your dedicated customers that have kept this company going , because without happy customers you may not have to worry about fixing tunes because there will be no customers to sell them to.
Posted: Thu Jan 03, 2008 9:26 pm
by Excursionist
Have still not heard from Diablo on my PATS system problem.
Maybe I can just get a refund?
I have not and will not reinstall and have lost confidence in the tool and programming.
Posted: Fri Jan 04, 2008 6:50 am
by vegasrjr
Calid - TNAA558
My Predator boots Ford _7_3 Rev level 8r02 , 2 months old...I updated per instructions to 7r19 with no problems..I have a 2002 Ford 7.3L....When I installed a tune to economy 60hp.The power was noticeably less than the original 60 hp. tune (8r02).
Today 11/04, I tried the 85Hp. tune and there was too much smoke on moderate acceleration...Now here is where it gets interesting when I put the tow tune in it today (11/04),it outperformed the 60hp. economy tune, and there was smoke upon moderate acceleration...So I put the 60hp back in and although there was hardly any smoke, but it does not seem to perform as strong as tow-tune.. With the original rev. 8r02 the 60 hp. was as powerful or more than the 85hp. that I have with the 7r19 update...Now I will be towing a 10,000 lb. trailer soon for 2k to 2.5k miles.. I need to use this tuner to help with the fuel mileage... But as I have stated the 7r19 update's tow tune is stronger than the 60hp
economy tune. What I'm afraid of is when I get on the road with limited internet access, I cannot update readily.. Also the tow tune on the original ( 8r02) causes the engine light to come on under hill towing conditions... Also I noticed the overhead trip/ mileage computer is way off when I use the tuner... Or I'm really getting 35mpg... Can you explain this...
Posted: Fri Jan 04, 2008 4:05 pm
by Modman58
Predator U7165 Cal ID VXAP2N2
2003 Ford F350 6.0l .
Having problems with it studdering or surging under high load condidtions on both the 60 and 100 hp programs.
Posted: Sat Jan 05, 2008 10:33 am
by jsavelli
Who is running this monkey farm??? Get your a$$ in gear and help these dudes out including me! What are the programers doing? Sitting around playing HOT POTATO or DUCK DUCK GOOSE possible MUSICAL CHAIRS. This is like waiting for my kids to get off the shitter..........HURRY UP ALREADY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted: Sat Jan 05, 2008 12:13 pm
by johnc
Software development is very difficult to do well. Embedded systems development is the most difficult form of software development. Then throw in the reverse engineering aspect of figuring out how the vehicle computers work... you realize that the manufacturers won't provide us with this information, right? There are no fixed schedules, just engineers grinding things out over long hours until finally the bits and pieces start to come together.
Posted: Sat Jan 05, 2008 1:15 pm
by jsavelli
yeah....and how many months have you guys been really working on getting this problem fixed??????? The only thing that is grinding is my teeth!!! I want a refund, this whole thing is BS! BS! BS!
RE: Re: RE: 2003 6.0 VXAP2n2 u7165 lastest rev
Posted: Sat Jan 05, 2008 1:41 pm
by jsavelli
what about Mikes post from DEC 21 "it won't take too long".......16 days later and still nothing. What type of men are you guys? When you say something is going to get done soon get it done soon maybe a week? BS! BS! BS!
Posted: Sat Jan 05, 2008 5:09 pm
by MikeWDiabloSport
Timing of resolving he issues isn't all that great with the holidays and everything.
I personally worked each day everyone else was on holiday (dec 25th, Jan 1..probably including you).
Trust me, it's moving along very quickly. There are over 70 tunes that need to be re-done, tested/verified.
While most people are home today watching bowl games on TV, some of us are here working on U7165.
