Updates
Post here with any questions regarding the use of the Ignition updater software for PC or Mac
Re: Updates
there is nothing to export with i2, the files are on the i2 drive, if you restored the stock tune there will be nothing to see.
If nothing else please post the info.xml file from the intune drive.
cmolnaird
Re: Updates
Post by cmolnaird »
Ok
Re: Updates
you dont export anything sir, they just sit on the drive.
cmolnaird
Re: Updates
Post by cmolnaird »
Thanks. :) . Looking for the 87 octane tuner with rev limiter and top speed limiter removed.
Re: Updates
the info file says the tool is married, there should be fines in the tunes folder under your VIN.
cmolnaird
Re: Updates
Post by cmolnaird »
I don't seem to have a tunes folder
Re: Updates
what else is on the i2 drive with the info file?
you should see this:
cmolnaird
Re: Updates
Post by cmolnaird »
I don't see a tune folder at all. :(
Re: Updates
can you go back to the vehicle and reload the tunes?
are the other folders there?
newcombpatrick
Re: Updates
Post by newcombpatrick »
I loaded the 93 octane tune without adjusting the speed limiter and it loaded fine. The truck is running fine now. The issue that I have now is I can't turn my MDS off. I'm running a custom tune from HEMIFEVER and when I attempt to turn my MDS off after I apply the tune, I go back and the tuner is showing that MDS is still on. Any ideas. It did the same thing when I tried it with the stock 93 octane tune. Thanks.
Re: Updates
have you tried setting mds off then loading the tune to see if its off in the truck?
bham
Re: Updates
Post by bham »
cmolnaird wrote:Ok
has your problem been taken care of. i have the same missing updater message in my info file and the intune will not save downloads
Re: Updates
bham wrote:
cmolnaird wrote:Ok
updater missing is normal, what do you mean wont save downloads?
cmolnaird
Re: Updates
Post by cmolnaird »
Ok i got a new i2 programmer. Looking for 87 octane tune with speed limiter and rev limiter removed. Thanks for all the help.
Re: Updates
the 87 tune should be inthe tool...
Return to “Ignition updater”
