Page 2 of 2
Re: 2006 Dodge PowerWagon NOT SUPPORTED!
Posted: Fri Jan 13, 2017 2:58 pm
by SUPERPOWERPHIL
I plug in
the tuner gives me the usual prompts and I load the 87 octane tune
then it gives me the wont read prompt and I disconnect.
I'll make a small video of doing it. back in 15
Posted: Fri Jan 13, 2017 3:28 pm
by SUPERPOWERPHIL
all right, the 87 octane perf tune went in, and now I have zero throttle. I do have files to send this time.
Video was too big to upload
Posted: Fri Jan 13, 2017 3:41 pm
by SUPERPOWERPHIL
gonna try and put it back to stock now, got kids to pick up and dogs to drive around!
thanks for the help guys
ps; got the stock tune back in, seems to work fine with stock tune.
Posted: Fri Jan 13, 2017 4:03 pm
sound slike you may have used easy tune to load 87 and disabled the speed limiter, use advanced for now and that wont be an issue.
Posted: Fri Jan 13, 2017 7:27 pm
by SUPERPOWERPHIL
mikel wrote:sound slike you may have used easy tune to load 87 and disabled the speed limiter, use advanced for now and that wont be an issue.
use advanced and don't touch the speed limiter, I'll try that.
Any particular reason why the tuner would do that? Is there a reset setting you can tap into to fix whatever it doesn't like doing? This is scary stuff Mike, I get uncomfortable when uncomplicated gets complicated.
Let me know if you require the tuner itself to fix the issue. I'll pack it up and mail it to ya.
Cheers,
Phil
Posted: Fri Jan 13, 2017 7:47 pm
by SUPERPOWERPHIL
So, when I plugged in the scan tool cable I noticed some corrosion on the OBD plug on the truck, not a lot but ya never know. Cleaned that and retried installing the tune with Mikes advice. Advanced installation worked, then I re adjusted the tire size and called it a day. IT WORKS! What a sweet deal, the truck is crisp and I even adjusted the throttle response to max setting, and it worked.
Thank you for the support and patience, can't be easy with us fat fingered wrenches hitting the wrong buttons and misunderstanding commands. :normal:
Looking forward the the cam and blower install next summer.
Cheers guys,
Phil
