2012 Dodge Challenger 3.6 Intune Problem?
SuaveRT
Re: 2012 Dodge Challenger 3.6 Intune Problem?
Post by SuaveRT »
Very important, when using the key. When it says to turn key then back on, you must cycle key two times to the left in order for it to be legit. Intune will recognize turning the key one time to the left to turn off, but that can get you errors. If that doesn't work call me and I will walk through other things with you. I will shoot you a pm with my number.
SuaveRT
Post by SuaveRT »
Hell I just notice that all my PM's are sitting in my outbox, but won't send. Mike!!! What to do??
ummm, what?
if you are getting failure at the end of the key cycle, leave the key in the RUN position and click the check marks on the tool to proceed.
SuaveRT
Post by SuaveRT »
Hey mike anything extra I need to do to make my PM's go out, they say it was sent, but they sit in my outbox not sent box.
They sit in the outbox until they are read by the person you sent them to.
I do not check PMs here, Id never get any work done....
SuaveRT
Post by SuaveRT »
thats kool, i didnt send any to you. i know you are busy... but to other members
tb632
Post by tb632 »
Has anyone had luck resetting the transmission adaptives? Every time I try to reset the transmission on my 12 challenger it fails. Everything else works fine with the diablo tune
SuaveRT
Post by SuaveRT »
tb632 wrote:Has anyone had luck resetting the transmission adaptives? Every time I try to reset the transmission on my 12 challenger it fails. Everything else works fine with the diablo tune
Haven't tried it yet, but a thing to do is after tune has been placed on and car has started, turn car off and go back in same tune. Then go straight to Transmission, and Rest TCM Adaptation. Then choose back until it says install tune. It will not interrupt your current tune that is already there, but simply change a portion of what's already installed.
Warmanr
Post by Warmanr »
Same with mine cannot get the adaptives to reset
Garza
Post by Garza »
Grandpa wrote:Take the traction control off. You will light up the tires, but your brakes won't hardly stop the car. So be careful with traction control off. Once you cycle the key to off your traction control will come back on. Recommend just using the traction off button in dash.
I took my traction control off , and my brakes work fine!! Must be something wrong with your car!!
Grandpa
Post by Grandpa »
Work better this time.
But not good for high speed.
chingon863
Post by chingon863 »
What where the benefits with the diablotune. I removed traction control and all the lights on the dash lit up :(
diablo tune is a performance tune for premium fuel.
Disabling TC disables ABS as well, all the lights will come on.
Garza
Post by Garza »
I can't find 93 octane , can I use 92 octane on the diablotune?
Id use the 91 tune if all you have is 92 octane.
