Page 3 of 3
Re: Trinity upgrade
Posted: Wed Dec 05, 2012 7:25 pm
by Mike_Levy
Enjoy what? He's saying it still doesn't work?
Re: Trinity upgrade
Posted: Thu Dec 06, 2012 12:44 pm
must have replied to wrong thread...
OP, i dont see any errors/problems with what you posted?
Last image says it was successful, go to the vehicle, and go go the performance menu, and it will load the update to the vehicles pcm and then allow you to tune it.
Re: Trinity upgrade
Posted: Thu Dec 06, 2012 1:52 pm
by Tndias
Mikel,
The problem is that is does the update, it says that was sucessfull, but if I replug the unit in the car I still get the message that vehicle needs to be updated. And when I plug the unit back i the pc, I get the same message that the tool needs to be updated, I update, but if I replug on to the PC it still takes me to the upgrade step again, like if the upgrade wasnt done.
Re: Trinity upgrade
Posted: Thu Dec 06, 2012 3:37 pm
Tndias wrote:Mikel,
post a new copy of the info.xml file please.
Re: Trinity upgrade
Posted: Fri Dec 07, 2012 1:31 am
by Tndias
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM4 at 57600 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Trinity'.
Serial number = '6K1PD0F-1'.
Part number = 'trinity_manager'.
CROM version = 'trinity_manager-9t74 08/09/2012 05:55:00 PM boot4'.
Vehicle VIN = ''.
Vehicle Calibration = ''.
Original backup NOT saved.
Tool is Married FALSE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are NOT supported.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is MANUAL.
Tool registration is SUPPORTED.
Tool does NOT support multiple ECUs.
Tool reports 1 ECUs.
Multi ECU Backups : 0
Marriage VIN :
Tool ID :
Desc :
Multi ECU Tuning : 0
Server:
Re: Trinity upgrade
Posted: Sat Dec 08, 2012 12:04 pm
by Tndias
Mikel,
The Tool Worked! I was able to apply the 91 tune to the truck and it is working very nice. I was also able to modify the parameter for the speed limit, but unfortunatly I was unable to modify the tire size.
I get the following error....
Can you please help?
Re: Trinity upgrade
Posted: Sat Dec 08, 2012 12:05 pm
by Tndias
this is my tol info...
Part number = 'dcx_gas'.
CROM version = 'dcx_gas-1r09e 11/28/2012 12:51:33 PM boot4'.
Vehicle VIN = '1D7RV1CT5BS691625'.
Vehicle Calibration = '68059130AH'.
Original backup SAVED.
Tool is Married TRUE.
Calibration Updates are SUPPORTED.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool SUPPORTS multiple ECUs.
Multi ECU Backups : 1
Marriage VIN : 1D7RV1CT5BS691625
Tool ID :
Desc :
PCM : 68059130AH
Multi ECU Tuning : 1
Name: PCM, TuneID: Perf 91oct, Modified: yes, Lock: No, Erased: No
Server:
