Page 3 of 5
Re: Trans. tuning lost since 1r13c update
Posted: Fri Jul 10, 2015 10:12 pm
by Flee
bump
Posted: Thu Jul 23, 2015 3:27 pm
by Flee
Flee wrote:bump
B to the Ump!
Any update?
Posted: Thu Jul 23, 2015 3:51 pm
by frenchbee2306
getting tired of this fight....
it seems that they do not want to help us
I am disapointed
Posted: Fri Jul 24, 2015 8:26 pm
by Flee
Agreed French, we need an update, I'm tired of having a $600 paper weight.
Posted: Fri Jul 24, 2015 11:56 pm
by peakg
It is taking forever. I switched from an Intune to a Trinity and lost my hemifever TCM tune. But my trinity never read the TCM, no backup, nothing! Thinking of going back to intune so I can run my custom TCM tune! I think they are more worried about the newer vehicles since this only happens on the '05-'06. We don;t matter anymore!
Posted: Sat Jul 25, 2015 8:50 am
by speedy
It's been a little over 2 years since I came here with a TCM tuning issue (5/13), that shortly after progressed into what it is today. I still can't even adjust my tire size. Nothing has been done for either. I was always looking for them to post some guinea pig Software updates for us but not a single one that I know of. I no longer driving my truck and I would be willing to try anything. Even send them my pcm/tcm and tuner if that would help find a fix for us. This has gone on long enough.
Posted: Tue Aug 18, 2015 6:39 pm
by kamanhart
Pretty big update guys! The issue isnt completely fixed but ground has been gained. I reset back to stock and uploaded to the newest DCX crom file. I retuned with the 93 octane and diablo custom trans tune, It went through the whole process and at the end before it shuts off when it tells you what tune was loaded both the trans tune and pcm tune showed up. Once it restarted I did the normal checks and still shows no TCM CAL ID and it doesnt show the last TCM tune written like we are all used to.
I got a wild hair and had my tuner write me a custom TCM tune again and tonight i went back to stock again and just straight from the get go loaded the custom TCM and PCM tune and gave it a shot. IT WORKED, it showed the tune was loaded and everything was great. Its still no show on the call id for the TCM but a test drive confirmed the tune loaded up and worked.
I think the issue lays somewhere, at least for me, that i always tried loading the diablo tunes first and then loading the custom tunes. Doing it that way it locks up the TCM portion and doesnt allow for communication, but if you just skip straight to the custom tune it still has a bridge for communication so everything will load up correctly.
Posted: Wed Aug 19, 2015 8:18 am
by FlatTop
So what the skinny on this issue ? Any updates on a fix ?
Years ago I had issues with BS updates and lost out myself. Heck I even lost touch screen on Trinity. lol
EXACTLY why I make damn sure I'm not on line when I hook up the tool.
From being an old post, is there been a fix ????
FT
EDIT as the days pass, other tuning options are getting better and better. In 6 more months id bet
trans tuning and complete working software will be and is becoming available.
Posted: Thu Aug 20, 2015 6:28 pm
by speedy
Unfortunately the latest revision did not fix mine. The tool still only sees the PCM. Sadly I will be selling my ram in the next few months but keeping the trinity. Looking at getting an R/T Durango if all goes well. Maybe the tuning on it won't be so glitchy.
Posted: Thu Nov 19, 2015 11:49 pm
by bbqman
I guess there's still no fix???? WOW!
Posted: Fri Nov 20, 2015 4:50 pm
by frenchbee2306
just to say.....
Since I cammed my truck with a Comp Cams 268 camshaft, I went with an HP Tuner custom tune.
Both engine and trans. were tuned
my trinity device is back in the box...
Posted: Tue Dec 15, 2015 2:03 pm
by sarah_ima64
any news ?
Posted: Tue Dec 15, 2015 11:57 pm
by speedy
frenchbee2306 wrote:just to say.....
So HP supports the 545rfe now? Do you know if they support the smaller 4.7L? My brother in law uses HP to tune his turbo LS engine. So i may give him a shout if they support my engine.
Posted: Wed Dec 16, 2015 4:36 am
by frenchbee2306
yes the 545RFE is now supported by HP Tuners and also the 4.7L engine
Posted: Wed Feb 03, 2016 11:39 am
by AZHEMI
I get the same msg when I go to put my custom TCM tune on my trinity... my custom PCM tunes load just fine but still don't have TCM tuning options. I called their tech support and his flat out answer was, that the TCM support module was not put in the trinity and it was hit or miss. I asked if they were going to put it back in the DCX crom file-he said NO and it is what it is. That's the tech. dept telling me this-- no fix even in the DCX 1r13f
