Page 4 of 5
Posted: Wed Oct 21, 2009 2:17 pm
Christopher, please try this update and see if it has support for your truck:
Posted: Thu Oct 22, 2009 9:36 am
by ckeene
downloaded...now pops up"the application is missing or corrupt". as far as it goes, no menus at all. works less than before.
Posted: Thu Oct 22, 2009 9:46 am
by ckeene
reinstalled 9r07 and back working
Posted: Thu Oct 22, 2009 9:47 am
by ckeene
summit racing....very first post
Posted: Thu Oct 22, 2009 9:57 am
by ckeene
tried 9t08e againjust to double check, same thing
thanks for the try though
Posted: Thu Oct 22, 2009 10:45 am
ckeene wrote:tried 9t08e againjust to double check, same thing
when you say same thing...what do you mean?
still unsupported?
Posted: Thu Oct 22, 2009 11:57 am
by ckeene
still unsupported
Posted: Thu Oct 22, 2009 12:14 pm
Sounds like it is not loading correctly, let me email it to you....
Posted: Thu Oct 22, 2009 12:40 pm
by ckeene
installed on tool . does same thing as 9r07
only tunes on there is modify stock hp, and orginal back up. tried to change tire size and it says i need a free download.
Posted: Thu Oct 22, 2009 3:38 pm
by concoursd
Well, you should be able to return it to Summit Racing if you want to pull the rip cord and bail.
Its up to you. I would keep working with Mike if I was you but it is your choice.
Posted: Thu Oct 22, 2009 3:40 pm
ckeene wrote:installed on tool . does same thing as 9r07
I have them working on a new update now...
Posted: Thu Oct 22, 2009 3:41 pm
by concoursd
Mike to the rescue.
And Mike, when you get done helping him, please research and develop the TCM support for the U7194 and U7191 GM Gas Predators...LOL
your the man, you can do it, stop holding out on us LOL
Posted: Fri Oct 23, 2009 8:47 pm
by ckeene
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM4 at 115200 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Predator'.
Serial number = '218120350'.
Part number = 'u7193'.
CROM version = 'u7193-9t08e 10/08/2009 02:11:41 PM boot4'.
Vehicle VIN = ''.
Vehicle Calibration = ''.
Origional backup NOT saved.
Tool is Married FALSE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are NOT supported.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is NOT supported.
Tool does NOT support multiple ECUs.
Config INDICATES multiple ECUs.
Tool reports 1 ECUs.
Posted: Mon Oct 26, 2009 9:58 am
new crom sent....
Posted: Mon Oct 26, 2009 1:44 pm
by ckeene
good deal...at in-laws house right now will load later this afternoon.
i did try out the new update on my u7198 on my 02 8.1 the other day and finally had time to take the truck around the block...man that thing runs, just need to dial it in.
keene
