2015 Eco Boost Dead peddle Info Thread.
Re: 2015 Eco Boost Dead peddle Info Thread.
2015 F150 FX4 3.5 Ecoboost
Here is my last tune using I1
Would like a 87 tune
- info.xml
- (1.9 KiB) Downloaded 292 times
not sure what one you need so here you go this is the 87 tune
- PCM_PKCMAW3_LastTuneWritten.frg
- (165.47 KiB) Downloaded 331 times
- info.xml
- (1.97 KiB) Downloaded 327 times
DiabloMatt
juice055 wrote:not sure what one you need so here you go this is the 87 tune
juice055.....here is yours. please try it out asap.
save that file and load it into tool as custom tune. then flash into truck.
- pcm_pkcmaw3_TEST.frg
- (145.71 KiB) Downloaded 291 times
DiabloMatt
speegee: i need you to physically load the tune you want into the truck first. then attach the "last tune written" out of the tool so i can modify it.
Installed tune and still have no pedal
DiabloMatt
juice055 wrote:Installed tune and still have no pedal
ok please post the last tune written again.
here you go
DiabloMatt
juice055 wrote:here you go
ok let me see. thank you
ok, try this on
looking for a 87 tun
- PCM_PKCMAH2_LastTuneWritten.frg
- (165.45 KiB) Downloaded 297 times
Matt,
I sent you a PM with a suggestion in it. Let me know if you are interested.
Frank
Frank
Matt,
Here is my last tune written. see what you can do. I have a trinity
I sent you a PM also
- PCM_PKCMAW3_Premium_Fuel_Performance_.frg
- (9.25 KiB) Downloaded 332 times
DiabloMatt
kellyfj10 wrote:Matt,
kelly can you save this on your tool as a custom tune and load it in your truck please. it has some changes based on what you described to me.
- TEST_.frg
- (145.06 KiB) Downloaded 263 times
Installed the tune. Dead pedal first key turn.DiabloMatt wrote:kellyfj10 wrote:Matt,
DiabloMatt
ok next thing..... can you please post your original backup tune. i have something else up my sleeve.kellyfj10 wrote:Installed the tune. Dead pedal first key turn.DiabloMatt wrote:kellyfj10 wrote:Matt,
Here is my backup file
- PCM_PKCMAW3.frg
- (193.39 KiB) Downloaded 282 times
