Just emailed all 3 of you a new crom, please give it a shot and let us know how it works.
Will not save the original tune
The cables ar eavailable at any computer supply store.
USB to serial cable and a 12v 1 amp power supply.
Thanks...
BTW, anyone else get a chance to try this out?
Thanks...
Any feedback here guys???
Anything?
RE: programmer problem
same problem with my 2005 6.0rattler wrote:tHAT IS JIFFJAR PROBLEM, RATTLER HAS NOITHING ON THE PCM AND PCM IS CLEAN STILL WILL NOT SAVE TUNE, SO IF THERE IS NO CURE AND CAN NOT BE FIX THEN THE DIABLOSPORT WILL NOT WORK AND I CAN GET A REFUND, I WOULD RATHER SEE IT WORKING THAN RETURNI IT, CAN WE FIND A CURE.
i just got my u7165 and it won't work on my truck.
same problems as the others.says key not on/starts to load then fails/says down load not complete/gives me a -10 .
I bought this truck new.it has only been in the shop oncefor a oil change and has never had the pcm touched.
has only 4500 miles on it.This unit should be totally updated seeing how it is new correct?
after reading all the issues with the others peoples problems I may return my unit to the vender i bought it from.
I have a 30 day return .
