Will not save the original tune
Just got my tuner and it will not save my original tune, what could be the problem, or what can I do to correct the problem
RE: Will not save the original tune
Is this a 7.3?
Sounds like a chip is in there, remove it and all is well...
Not sure about this...what revision is on the Predator?
Plug the tool in and go to options/troubleshooting/show calid and tell me what it says there as well.
Are you sure the other module is fully disconnected?
Does it start to read and then fail?
What revision is on this tool?
revision?rattler wrote:calid says VXAP2N2HEX
programmer problem
Version: V.9r03, serial: 009f90 hardware: univ_rev2, so now what do I do to fix this problem
programmer problem
NEED HELP TO SOLVE THIS PROBLEM
The -10 is telling us the PCM does not have a stock tune.rattler wrote:No this is a 6.0L in a 2003 F250, Every time I try to load a program it comes back saying could not save original program with a -10, just had the pcm flashed at the ford dealership.still does the same thing. I have a u1765 programmer. What do I need to do.
I'd try reflashing the truck back to stock at the dealer.
It would appear that your Edge device has not come off cleanly...if the PCM is fully stock, the Predator will read it.jiffjar wrote:other module is fully out of the loop, and yes it starts to read get to only 0 of 1% and then fails.
programmer problem
tHAT IS JIFFJAR PROBLEM, RATTLER HAS NOITHING ON THE PCM AND PCM IS CLEAN STILL WILL NOT SAVE TUNE, SO IF THERE IS NO CURE AND CAN NOT BE FIX THEN THE DIABLOSPORT WILL NOT WORK AND I CAN GET A REFUND, I WOULD RATHER SEE IT WORKING THAN RETURNI IT, CAN WE FIND A CURE.
