Will not save the original tune
rattler
Post by rattler »
Just got my tuner and it will not save my original tune, what could be the problem, or what can I do to correct the problem
RE: Will not save the original tune
Is this a 7.3?
Sounds like a chip is in there, remove it and all is well...
rattler
Post by rattler »
No this is a 6.0L in a 2003 F250, Every time I try to load a program it comes back saying could not save original program with a -10, just had the pcm flashed at the ford dealership.still does the same thing. I have a u1765 programmer. What do I need to do.
Not sure about this...what revision is on the Predator?
Plug the tool in and go to options/troubleshooting/show calid and tell me what it says there as well.
rattler
Post by rattler »
calid says VXAP2N2HEX
jiffjar
Post by jiffjar »
i am having the same problem..just got the tuner today and it will not save stock tune...i have the edge chip on my 03 f250 6.0 but i dissconected it to upload the tune, also aftermarket sterio system unpluged...what could the problem be? any info would be a big help..thanks
Are you sure the other module is fully disconnected?
Does it start to read and then fail?
What revision is on this tool?
rattler wrote:calid says VXAP2N2HEX
revision?
jiffjar
Post by jiffjar »
revision is V.9r03
calid is VXAP2N2HEX
i had my truck reflashed at ford today. the problem remains the same...sugestions?
jiffjar
Post by jiffjar »
other module is fully out of the loop, and yes it starts to read get to only 0 of 1% and then fails.
rattler
programmer problem
Post by rattler »
Version: V.9r03, serial: 009f90 hardware: univ_rev2, so now what do I do to fix this problem
rattler
programmer problem
Post by rattler »
NEED HELP TO SOLVE THIS PROBLEM
rattler wrote:No this is a 6.0L in a 2003 F250, Every time I try to load a program it comes back saying could not save original program with a -10, just had the pcm flashed at the ford dealership.still does the same thing. I have a u1765 programmer. What do I need to do.
The -10 is telling us the PCM does not have a stock tune.
I'd try reflashing the truck back to stock at the dealer.
jiffjar wrote:other module is fully out of the loop, and yes it starts to read get to only 0 of 1% and then fails.
It would appear that your Edge device has not come off cleanly...if the PCM is fully stock, the Predator will read it.
rattler
programmer problem
Post by rattler »
tHAT IS JIFFJAR PROBLEM, RATTLER HAS NOITHING ON THE PCM AND PCM IS CLEAN STILL WILL NOT SAVE TUNE, SO IF THERE IS NO CURE AND CAN NOT BE FIX THEN THE DIABLOSPORT WILL NOT WORK AND I CAN GET A REFUND, I WOULD RATHER SEE IT WORKING THAN RETURNI IT, CAN WE FIND A CURE.
