i1000 backup / restore. locked
eazycheeze
Post by eazycheeze »
hello, ok so ive read plenty of topics already concerning this. a while back say 4 years i tuned one of my vehicles, and i thought i removed it. My issue now is i am tracking which vehicle it is linked to as it will not restore backup. the vehicle i suspect that has it is saying no backup stored. i then try and tune it to make a backup and it says no open licence so it makes me beleive its the wrong vehicle but it will not work on any others either. My question is, how can i know which vehicle its linked to as im trying to tune my new truck.
heres the info.xml
Code: Select all
<?xml version="1.0"?>
-<tool_info>
<main svn="9115" sw_rev="1r04j" full_version="InTune-1r04j 03/14/2016 10:51:37 AM"/>
<registration status="0" sn="KUFZE25-8"/>
<cal_id PCM="05187490AF"/>
<restore bc="8" vin="1J4GA39178L606912" id="0"/>
<system_db vin="1r01g" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01f" mfr="DCX"/>
<db pid="1r01b" tune="1r02h" mfr="FORD"/>
<db pid="1r01a" tune="1r02u" mfr="GM"/>
-<license tuned="1" avail="1">
<tuned vin="1G1PH5SC7C7383273"/>
</license>
<updates count="5"/>
<oem tool_oem="DIABLO"/>
<reg reg="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"/>
</tool_info>
says a ford and gm, but i do not own a ford. and that vin in the file doesnt seem to be adding up too any of my vehicles unless that is something else?
thank you.
eazycheeze
Re: i1000 backup / restore. locked
ok so i checked the vin out on the info.xml, it is linked to my vehicle. so now my issue is that, it will not backup as it says it does not exist. What would be the next step in restoring to stock and releasing the tuner? as stated, if i hit write tune, it says no open licence however this xlm file is clearly showing its linked to it and that would make sense as the last vehicle. However there isa slight chance i did not write a tune but just did quick adjustments for tire height, etc. if thats the case how do i reset the quick adjustments so it releases the tuner? thank you
Edit. Added pics of errors. Oddly enough i am getting 2 different vins during usage attempting to backup. Wonder how thats possible and how that can be fixed.
its married to this:
a 2012 GM
It likely needs to be updated before it will restore properly.
Those ollllld discontinued inTune i-1000 tools haven't been supported for at least 10+ years... there are no updates for it... can't do anything for it...
eazycheeze
hi, thanks mikel, i totally forgot about that vehicle. thank you itll probably work. and i figured thered be little support for it. the app cant even connect which is unfortunate incase i had missed some updates since i bought it.
that's because those ollllld discontinued i-1000's are not supported anymore... The old update server that was used for those old tools for updates, is no longer in existence, hence why the update program won't work for it...
eazycheeze
Thanks much appreciated
Got it restored and now i can use it on the truck. Got a question. This tuner doesnt offer a 91 octane for a 2014 gmc sierra?
Just got diablo tune
87
Mpg
And modify stock
I thought i could do a 91 tune as thats all we have here.
"Diablo Tune" is the 91/93 octane tune...
eazycheeze
Hey monte, oh ok, so i can run 91 premium on it, just seen its 93 somewhere and wanted to ask first thanks
yeah on most gm trucks the Diablo tune is for a minimum of 91 octane.
