Can you install a 2002 Powerpuck on a late 2001 Dodge?
PowerPuck/Extreme PowerPuck Support
MarkMiller
Post by MarkMiller »
I have a Powerpuck D7155 with plug # 04113 that was designed for the 2002 Dodge Diesel Cummins. My truck is a late model 2001 Dodge Diesel Cummins. I was able to download the manual for the 2001 D7154 and I could not download the manual for the 2002 D7155 as there was some kind of file error. In the D7154 manual, the installation cables in the manual appear to be different thank what I have on my late model 2001 truck - they seem to be the same for the 2002.
Can you please let me know if you think I would be able to use the D7155 on my late model 2001 Dodge Cummins? If so, would you mind sending me the 2002 manual?
Note: This puck does not have the integrated boost control cable.
Thanks for your help!
concoursd
Post by concoursd »
go to this webpage:http://www.concoursdirect.com/dodgepowerpuck1.html
it has the information you need to identify your power puck, which part number fits your truck, and which connectors it needs. It also has every power puck install instruction sheet.
Return to “PowerPuck/Extreme PowerPuck”
