General Comment
Posted: Mon Oct 06, 2008 10:27 pm
by ropnjessi
I switched to the Smarty sometime ago, but I have recently sent the Smarty back for an upgrade. So in the meantime I've reloaded the Predator and I have to say I forgot how good the power is, been running the Extreme mode with the TST. This morning on my way to work I hit 120mph so I can verify the speed limiter works
, if the Predator was able to change some Torque Management settings, the Predator would be a fair contender against the other competition. I'll always keep the Predator around, good job on the latest upgrades.
RE: General Comment
Posted: Tue Oct 07, 2008 12:43 am
by ModManiac
I have always thought that the predator makes great power on the 03-04 trucks compared to any other tuner out there. Do you feel that it makes alot more than the smarty? I am guessing your getting it sent back for the POD? Mikel was supposed to e mail me some tunes with decreased Tq management but ive never recieved them. I bet your lovin that turbo.
Re: RE: General Comment
Posted: Tue Oct 07, 2008 10:47 am
ModManiac wrote:I have always thought that the predator makes great power on the 03-04 trucks compared to any other tuner out there. Do you feel that it makes alot more than the smarty? I am guessing your getting it sent back for the POD? Mikel was supposed to e mail me some tunes with decreased Tq management but ive never recieved them. I bet your lovin that turbo.
Hmmm...I dont write tunes....
Maybe it was Johan?
I'm sure if you shoot him an email and ask nice, he will be willing to take care of you.
Be sure to include your calid.
RE: Re: RE: General Comment
Posted: Tue Oct 07, 2008 2:21 pm
by ModManiac
Since Ive nerver used a smarty what advantages will I see with the tq management turned off/turned down?
Posted: Tue Oct 07, 2008 2:59 pm
Advantages....well, you'll be able to kill the clutch faster and maybe even break the tranny!
LOL, seriously, it keeps the PCM from limiting torque output, which really is not an issue when you have 800 or so ft/lbs at the tires...
Posted: Tue Oct 07, 2008 4:46 pm
by ropnjessi
The power is comparable to the Smarty, however there is no way to fine tune anything. But a lot of people prefer it this way. Yes on the POD, and yes I picked this turbo because its very streetable 450-525hp, it spools very fast and is great for towing with no surging at all. I dyno'ed 454hp/912trq. on the Predator "Tow tune", then I loaded the extreme and only hit 456hp/900trq. before I ran out fuel, I now have the FASS 150 hooked up, so it will be a different story next time.....
Re: RE: Re: RE: General Comment
Posted: Tue Oct 07, 2008 11:34 pm
by ModManiac
mikel wrote:Advantages....well, you'll be able to kill the clutch faster and maybe even break the tranny!
LOL try 463hp 1023tq with the rkl tunes and mp-8. Ive got a good clutch so id like to try it out, Ill send Johan an e mail. I know I need a turbo bad, my stocker sees 40psi sometimes so Im sure drive pressure is through the roof. How is the spool up with that turbo ropn? I usually drive around on the performance tunes and occasionally use my mp-8 and tow quite often.
Posted: Thu Oct 09, 2008 11:59 am
by ropnjessi
ModManiac wrote:mikel wrote:Advantages....well, you'll be able to kill the clutch faster and maybe even break the tranny!
As I mentioned above it spools very fast, my dyno was also based on the puc set on 60hp. I'll crank things up a notch now for the next roller run...
RE: Re: RE: Re: RE: General Comment
Posted: Sun Oct 12, 2008 5:35 pm
by CSchomer
I wish I would have had 9r03 installed last week so I could drop the rpms before my Az. e-test instead of 3500 when it was floored. But I don't know if it will do speed limiting with the stock backup - I haven't tried that yet. Craig
