i recently went to load the 'extrem RKL stack puff' tune and i flashed a diablo tune first then went to flasf the RKL tune and the programer showed "tune did not load into vehicle", from there it makes me load the original back-up. what does this mean? and what do i do from here?
truck is a 2003 H.O.
HELP PLEASE!!!!!!!!!!
"tune did not load"
RE: "tune did not load"
What revision are you running on the Predator?
i did download the 'pos tunes' to the programmer and it loaded quick and said it was succesful.
andygill17
i'm having the same problem on my truck. when I had the r30 version in, it would load all the RKL tunes fine, but when I updated to the 9r03 version, it will load the normal tunes fine, but says "tune did not load" when I try any of the RKL ones. any suggestions?
'03 cummins 6spd
con FE clutch
predator
Edge EZ
con FE clutch
predator
Edge EZ
andygill17
