just wondering if u can use the u7170 on the ford 2002 e350 vans with 7.3 ?
thx
Paul
Diablo Sport u7170 on e350 van ?
RE: Diablo Sport u7170 on e350 van ?
Should be fine.If you look in the pull down tab at the top of page under support.Click on product support then Click on the part # of the predator and follow .It list vans as well as trucks.Hope this helps.
2001 f250 CCSB 4WD 5"Exhaust,
BallBuster Turbo,ITP Regulated Return,03 Headlights
CCV-MOD,,AIH Delete,Built-Trans,Programmer,DIY Intake,EBPV delete,Boost-fooler,Gauges,305's
E350 U7170?
I installed this in a E350 2002 van to try, I heard it would work. He did gain power and it loaded fine but imediatly the overdrive light started flashing and the water in fuel light came on. Any thoughts, is this just not compatible?
RE: E350 U7170?
http://diablosport.com/index.php?module ... lay&pid=60
E series is listed as supported.
fordtech, what revision was on this tool?
Yeah, thats an OLD tool, and I cant really say what may have happened there, but there was a good reason we redid these tools.
I'd suggest the $99 hardware upgrade here to get on the latest revisions.
Well I would not mind sending it in if you are sure this will cure it. But I was just selling it to a freind so I am not sure he wants to put that kind of money into it. I have tw of these and was going to send mine in as well. Is there a price break to send two in at once and are you sure this is the fix?
No, it is $99 per tool, basically covers the cost of the new hardware and the labor to do it, not a money maker for us.
