Page 1 of 3
Throwing code P0603 when installed
Posted: Mon Nov 10, 2008 9:45 am
by grumpy929
I have a 2003 Excursion 6.0 (S&B intake, MBRP turbo back.....) The problem I am having is this: I took the truck to the dealer to flash the computer; when I tried to reinstall the Predator it would not install reading "vehicle not in database", no problem I updated the programmer to v.9r05. Now when the 100 hp tune is installed the truck throws P0603 powertrain control module Keep Alive Memory (KAM) error. Also when accelerating it will cut out and the pick right back up. And lastly the truck cuts off when I let off while going slow, but will start right back up (has not caused a big problem when out and about). Cal ID: VXAP2A2 U7165 pcm_6_0 v.9r05
Never had any trouble out of previous tunes prior to updating Predator
RE: Throwing code P0603 when installed
Posted: Mon Nov 10, 2008 9:48 am
by sohfast94
Could you send me your last tune written?
Posted: Mon Nov 10, 2008 10:16 am
by grumpy929
The prior tune is: v.8r14 which was the tune installed on the predator when purchased
Posted: Tue Nov 11, 2008 10:52 am
by grumpy929
When I posted yesterday, I missed a problem. The truck also throws code: P2290 Injector control pressure too low. If I remember correctly this code was also thrown before update. It doesn't seem to cause any problems. Any help would be greatly appreciated.
Posted: Tue Nov 11, 2008 10:56 am
by grumpy929
A little scatter brained today. The only other problem I am having is the tow/haul button blows out all guages on dash when pushed. I can't see how this would apply to the tuner but I thought I would throw it out there and see what came back.
Posted: Tue Nov 11, 2008 10:57 am
by sohfast94
Yeah that's definitely a wiring issue... Never heard that one before... check your grounds.
Posted: Tue Nov 11, 2008 10:58 am
by grumpy929
My thoughts exactly. Just have not found the right ground yet.
Posted: Tue Nov 11, 2008 11:02 am
by sohfast94
Lol the search continues.... I'll dig around see if I can find a diagram of them somewhere...
Re: RE: Throwing code P0603 when installed
Posted: Tue Nov 11, 2008 2:29 pm
by grumpy929
sohfast94 wrote:Could you send me your last tune written?
Is this the U7165_pcm_6_0-9r05.crom file of the predator that I have installed on the truck now ?
Posted: Tue Nov 11, 2008 2:30 pm
by grumpy929
RE: Re: RE: Throwing code P0603 when installed
Posted: Tue Nov 11, 2008 3:15 pm
by sohfast94
Yes that's the one.
Posted: Tue Nov 11, 2008 4:13 pm
by grumpy929
Email sent with tune attached. Thanks
Posted: Tue Nov 11, 2008 5:25 pm
by sohfast94
Replied. Try that.
Posted: Tue Nov 11, 2008 6:05 pm
by grumpy929
Installed; Initially threw P0603, which I cleared. Had a little surge when getting up to speed easy. Seems to have cleared after drive. Will drive for a few days and repost.
Posted: Tue Nov 11, 2008 6:13 pm
by sohfast94
Yeah I saw where it might have surge I though but you hadn't mentioned it so I wasn't going to touch it...
