If the 56 is different then the 57, how does the 59 work for both?
The wiring harness is the same so shouldn't you be able to flash the 56 and make it work like the 57?
Shouldn't you be able to flash both the 56 and 57 to make them work like the 59?
Just a thought and hence the name: what if
I ask too many questions don't I?
D7156 D7157 D7159
RE: D7156 D7157 D7159
59 replaced 58, not sure where you see that 59 will work for both?
My mistake I thought the 59 covered 03 - 07. I don't see a 58 unless that is no longer produced. I do see a 57 for 04.5 - 05.
Could the 7156 be flashed to the 57 or 59? If so how and if not why.
