Haze at idle
kw5.9
Haze at idle
Post by kw5.9 »
It is about 38* here in TX in the AM and i let my truck warm up for 10-15min and lately on the Exteme tune it has a haze while idleing, I also took my puck off because I saw some white smoke at start up, i was thinking it was a leaky injector, just checking to see if this is normal, and no i dont have the RP guage just yet to see if it is over fueling while idleing.
kyle
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
RE: Haze at idle
Not sure about that, maybe some others will chime in as to whether or not that seems normal...
kw5.9
Post by kw5.9 »
mike also i was going to hook up my puck again and i have a quadzilla boost fooler, should i plug the puck into the fooler or should the puck be on motor side and then the boost fooler?
kw5.9
Post by kw5.9 »
"bump" mike, any suggestions?
Plug the fooler in first, then the puck...
kw5.9
Post by kw5.9 »
Thanks!
smokenU
Post by smokenU »
so you can run a fooler and a puck and a preditor? how much does thiss really help boosT?????
o6,cold air,mp8,predator,afeelbow,turbo mods,strightpiped,2in leveling kit with 35/12.50/17 on stock wheels,and a ton off trans issues ofcoarse...
deezel_dawg
Post by deezel_dawg »
smokenU wrote:so you can run a fooler and a puck and a preditor? how much does thiss really help boosT?????
yeah...how does this help? i thought the puck did the boost fooling.
06 Dodge QCLB 4x4 5.9 Cummins. AFE TT, B&W Turnover, 4 in TBE , MAG-HYTEC TRANS PAN, A pillar EGT/TRANS Temp/Boost...LOCAL 824
Brooksville FL
RRAM
Post by RRAM »
I think the new power puck does fooling, the original puck does not boost fool,
Reg
2005 3500 Quad Cab Laramie L/B
Predator, AFE stage II, boost fooler
Pillar Mount gauges Billet low stall TC
pmcclain
Post by pmcclain »
I just purchased a Quadzilla Boost fooler. I have the Predator, and Performance Tune loaded. Was curious if a Puck was worthwhile, and is larger exhaust worthwhile.
concoursd
Post by concoursd »
larger exhaust is worth it. the extreme power puck is worth it in some respects because it gives you a dial to adjust the puck's power on-the-fly and the Predator has puck tunes already installed. It would make for a nice stack.
