Hello ,
There is a way to keep original parameter of the transmission with a diablosport 91octane tune? I dont like the feeling that the shifting does
Ram 1500 v8 hemi 2012
6 speed.
2012 Ram shifting with diablo tune
Re: 2012 Ram shifting with diablo tune
are you saying you dont like the shifts being firmer? or is it something else?
post the last tune written from the device please.
It's as if the transmission is hesitant to shift into certain gears and it seems like it slips sometimes. I would like the programming to not affect the transmission settings, is this possible?
thank you
thank you
the tuning will not cause hesitation or slipping, in fact its the opposite.
but, post the last tune written from the tunes folder on the device and I will undo all of the trans changes.
Just replace the transmission oil presure to stock setting please.
see last written tune in attached file
thank you
thank you
here you go.
yeah thank you so much
