How do i turn off MDS?
Neverstopfighting
Post by Neverstopfighting »
Hi.. 2012 Ram... Have a I3 diablosport.
Just did a cam swap and Hellcat lifters and mellings HV oil pump... I did the MMX no tune cam and lifter kit..
Long story short.. did a MDS full delete but how do i shut it off using the tuner so i dont get error codes?
In the parameters all i get listed is tire size and traction.. I did do the diablotune i read somewhere that disables MDS.. is this true? Or do i need a custom tune or download?
Re: How do i turn off MDS?
sounds like you are looking in the quick adjust menu vs the modify parameter menu.
Go to the tune menu, pick the tune you want, then select modify parameters. Go to MDS, set it off, save it, then back up and apply the tune to the vehicle.
