New beta for unsupported 04 and 08, tune changes as well
http://diablosport.com/downloads/predat ... xport.crom
*support for the new 04 and 08 calids
*Tune changes for ALL years for better shifts
*tire size change and key cycles issue resolved
Try it and let us know.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
need-a-cage
RE: New beta for unsupported 04 and 08, tune changes as well
Johan, is this the same change that you emailed me? I have not had a chance to try it out yet and am a little nervous after Randtx had issues.
Wait, you just edited my tune and sent it back to me. This is a crom update, so it is different or does the crom update just do the same thing to the tunes that you manually did to mine?
Thanks,
Craig
Thanks,
Craig
06 QC SLT Big Horn Hemi 2wd 20's,3.92's, Magnaflow, custom Y, Diablo, Edelbrock Shorties, modified K&N CAI.
14.64 @ 90.5 mph (short belt, no spare)
93 Stroked and Blown Mustang
10.84 @ 128.5mph
10.84 @ 128.5mph
All new, with support for the unsupported 04 and 08 calibrations.
These tunes have new shift parameters (that work properly), plus changes to the tunes for better WOT shift feel and reduced timing being pulled during the shifts.
So Mike do you think these would work on mine?
From having David's in house have you ID'd the WOT shifting back to 2nd prime problem?
need-a-cage
I think this is what Johan did to a tune of mine that he emailed me last week, but I will just update the crom and try this one.
The other tune was dropping the WOT advance to 14 degrees, which was an 8 or 9 degree drop on the shifts. Do you know what this one does? I never datalogged part throttle shifts, but it feels like the shift to 2nd still has too much taken out with the older crom. I will try this one and see if it helps that.
10.84 @ 128.5mph
10.84 @ 128.5mph
Re: RE: New beta for unsupported 04 and 08, tune changes as
I have not had a chance to discuss this with Johan, but he must be confident with it if he has released it.RandTx wrote:So Mike do you think these would work on mine?
I will ask him to chime in.
- chefred112
RE: Re: RE: New beta for unsupported 04 and 08, tune changes
I downloaded the file..will this affect the custom tune I have on the truck now? it sounds like the steps to apply the crom file is:
1) Set truck back to stock
2) connect tuner to pc, start ds downloader, send Crom file to tool
3) connect tool to truck and reprogram my custom tune...
sounds right?
Fred
sounds right?
Fred
-Fast Freddie-
05 Hemi QCSB
392 - 232/238 cam /heads/lt's/true duals/dual e-cutouts/cai/efan/3.92 gears/2600 stall verter/180 tstat/cat deletes
old 5.7- 214/218 cam/heads/lt's/true duals/dual e-cutouts/cai/efan/4.56 gears/2800 stall verter/180 tstat/cat deletes
05 Hemi QCSB
aussiedors
I am going to try it tonight also. Will let you know how it goes.
- chefred112
..I followed the procedure above and everything looks like it uploaded with no errors, however, even tho I modified TCM parameters, I did not see a TCM loading bar like I see with the PCM loading bar...is that ok not to see it?
thanks, Fred
thanks, Fred
-Fast Freddie-
05 Hemi QCSB
05 Hemi QCSB
So does this beta crom allow us to mess with tcm params?
Chefred, sorry if this is a dumb question but, what are the dual E cutouts on ur sign mean?
2005 Ram 1500 QC 5.7.
K&N cold air intake, LT headers, 2.5" true dual exaust with no cats...
- chefred112
..I'm runnin true duals...along the pipe I put a cutout (on both pipes) that has an electric "door" that I can open and close from inside the cab...I use this mostly at the track to really open up my exhaust...or scare people on the street...lol.. here's a vid when I ran a single e-cutout..
http://www.youtube.com/watch?v=bxtHLWZcWA8
-Fast Freddie-
05 Hemi QCSB
05 Hemi QCSB
- chefred112
here is what the cutouts looked like when the true duals were being fabbed in...then you jus add the e-valves to it..
- cutouts fabbed in..
- frednew1.JPG (101.88 KiB) Viewed 5053 times
-Fast Freddie-
05 Hemi QCSB
05 Hemi QCSB
im also running tru duals, whats opening the cut outs? i would like some info on this, id like to copy u LOL..chefred112 wrote:here is what the cutouts looked like when the true duals were being fabbed in...then you jus add the e-valves to it..
also, big fan of ur truck man..
oh an how u like the 4.10 gears? u happy with them? i hear every 1 using 4:56 an i was thinkin thats 2 much for me, mine is jus a 2wd, street, strip truck..
Ok so I jus installed the tune, an did a couple wot runs, I never touched the trans params, an everything in pcm params cept spark,added 11% , 0%, and leaned up 4%
And from a dead stop I mash the gas an the low end power seems to be better than the last tune I had, but in first gear an barely into second I had about 6.00 st knk retard at about 2.3k rpm an about 3k dropped to 5.00, 3.5k at 4.50,and 4k, 3.50 an shortly falls to 1.00 after bout 5k rpm, after shift all the way up to 80 mph no more than 1.50 st knk retard.
My question is, why is it so high in first gear? Is it the burn out? Would like some info.
An the 1-2 gear is nice now no pause just strait shift, an a longer tire scratch, I believe johan is on to somthing
Keep up the good work.
~Mitch
~Mitch
Johan, I recently loaded the DB for the first time last weekend (12/6) on my 08 and everything was accepted fine (stock with exception of cai). Had to do a calibration update only. My question is did the new calids come as part of that download I did and that may be why everything was accepted into my vehicle without problems or just lucky for my particular vehicle? Should I be trying the new crom for more improvements or is that just for the other 08 that had different calids/unsupported ones from mine? So far there has been harder shifts and improved acceleration--all things running/shifting smooth. Very impressed so far with 93 tune/difference.
