Page 1 of 2
2001 f350 wont start after loading any performance tune
Posted: Fri Dec 12, 2008 9:59 pm
by 4rddan
I just got my U7170 programer and when I load any performance tune it activates a anti theft program and the truck wont start. I have to reinstall the factory settings. I called tech support and they tried to help by changing the anti theft option in the code but that didnt work either. I'm kind of waiting for a answer with a programer that wont work. It has the v.9r03 program in it. Any ideas?
RE: 2001 f350 wont start after loading any performance tune
Posted: Mon Dec 15, 2008 11:56 am
by Phil
The tuner is looking into this issue for you. Thanks
Posted: Mon Dec 15, 2008 12:43 pm
by sohfast94
You're the one with the VRAA7 calid right?
Posted: Mon Dec 15, 2008 9:12 pm
by 4rddan
yes, VRAA7N7
Posted: Tue Dec 16, 2008 9:44 am
by sohfast94
Have you tried loading revision 9r04?
Posted: Tue Dec 16, 2008 7:05 pm
by 4rddan
No, when I was on the phone they told me it wouldn't help me it was aimed at the newer 6.4 trucks
Posted: Tue Dec 16, 2008 7:09 pm
by sohfast94
Alright welll. I would try it just in case...
Posted: Tue Dec 16, 2008 9:59 pm
by 4rddan
OK, I loaded the v9R04 version. I downloaded the 85hp program in the truck and it wouldn't start. I changed it to the tow tune with the anti theft turned on and it didn't start then either. I put the factory tune back in and it starts. Another question, when I was first trying to get it to work I cleared the codes thinking that might help and when it didnt I cleared the KAM. Now it shows a code for that. Is that a problem or will it cause me problems? What is the KAM and what does it do?
Posted: Wed Dec 17, 2008 9:28 am
by sohfast94
KAM = Keep Alive Memory... It clears every time you program or disconnect the batteries for any given amount of time. Do you ahve an excursion or something?
Posted: Wed Dec 17, 2008 1:46 pm
by 4rddan
2001 f-350 sd with mbrp 4" exhaust and afe stage 2 intake. When I bought the truck it was stock.
Posted: Thu Dec 18, 2008 2:54 pm
by 4rddan
So... You guys are still working on the not starting after tune downloaded problem. Right?
Posted: Thu Dec 18, 2008 4:07 pm
by sohfast94
Yeeeeessss....
Re: RE: 2001 f350 wont start after loading any performance t
Posted: Thu Dec 18, 2008 5:53 pm
by sohfast94
4rddan wrote:So... You guys are still working on the not starting after tune downloaded problem. Right?
Should be done and ready to test in just a bit.
Posted: Fri Dec 19, 2008 1:39 pm
by sohfast94
Try this and tell me what it does now.
Posted: Fri Dec 19, 2008 9:56 pm
by 4rddan
I downloaded the file and loaded it on the tool and now the tool says "the application is missing or corrupt" and wont do anything.I push continue and it restarts it and it says the same thing. It wont start at all and I cant connect to it with the computer either to try and reload the program.
