Page 1 of 8
U7130 Extreme RKL 200hp & Perf Stacker tunes Downloads
Posted: Fri Apr 27, 2007 1:54 pm
by johan
Ok I figured it would be easier for you guys to download these custom tunes from HERE:
For pre 8r28 revision
05xxx http://www.diablosport.com/downloads/pr ... _tunes.drd
12xxx http://www.diablosport.com/downloads/pr ... _tunes.drd
15xxx http://www.diablosport.com/downloads/pr ... _tunes.drd
20xxx http://www.diablosport.com/downloads/pr ... _tunes.drd
25xxx http://www.diablosport.com/downloads/pr ... _tunes.drd
Performance Stacker Tunes
05xxx http://www.diablosport.com/downloads/pr ... _stack.drd
12xxx http://www.diablosport.com/downloads/pr ... _stack.drd
15xxx http://www.diablosport.com/downloads/pr ... _stack.drd
20xxx http://www.diablosport.com/downloads/pr ... _stack.drd
25xxx http://www.diablosport.com/downloads/pr ... _stack.drd
Each one of these files contains 4 different Extreme RKL tunes:
Extreme RKL
Extreme RKL with less timing
Extreme RKL for stack
Extreme RKl for stack with less timing
For post 8r28 revision
05xxx http://www.diablosport.com/downloads/pr ... _toons.drd
12xxx http://www.diablosport.com/downloads/pr ... _toons.drd
15xxx http://www.diablosport.com/downloads/pr ... _toons.drd
20xxx http://www.diablosport.com/downloads/pr ... _toons.drd
25xxx http://www.diablosport.com/downloads/pr ... _toons.drd
The "ext_puff_toons" contain:
Extreme puff tune
Extreme RKL tune
Extreme RKL puff tune
Extreme RKL puff tune w/ no timing added
The "stack_puff_toons" contain:
Extreme RKL puff stack tune
Extreme RKL puff stack tune w/ no timing added
Performance stack tune
Where 05xx applies to any calid starting with 05, 12xx, 12 etc etc.
PLEASE NOTE: These tunes WILL deteriorate your stock transmission post haste.
RE: U7130 Extreme RKL 200hp & Perf Stacker tunes Downloa
Posted: Tue May 29, 2007 9:10 pm
by cameroneod
Quick question. I can load http://www.diablosport.com/downloads/pr ... _stack.drd into my predator, but it doesn't show up as four tunes, and when I try to load it, the truck acts like its back to stock. Any idea what I could be doing wrong?
Posted: Thu May 31, 2007 10:41 am
by duallydave
the performance tune doesnt have 4 versions to choose from,only the extreme,i didnt notice much diference in the performance stack tune from stock either,its designed for the puck,probaly doesnt have any presure added.
Posted: Thu May 31, 2007 8:30 pm
by cameroneod
Ive got the puck.
Posted: Fri Jun 01, 2007 8:58 pm
by duallydave
maybe the performance stack tune is for economy only and doesnt add much fueling.i tried it and didnt think much of it.i think the extreme rkl tunes are the besst with or without the puck.
Posted: Fri Jun 01, 2007 10:59 pm
by 03dodgeoffroad
i am having a problem downloading the exteme rkl i click on the lick and i trys to download the .drd file and the download manager takes the .crom what am i doing wrong????? i want to have fun and play with the big program
Posted: Sun Jun 03, 2007 8:31 am
by modified03
what what exactly am I getting from the performance stacker tune hp wise and all. Does this program actually add horsepower or what?
Posted: Wed Jun 06, 2007 8:21 pm
by cameroneod
Guy on tdr just did dyno runs with the predator/puck. He made more hp without the puck.
Posted: Fri Jun 08, 2007 6:46 pm
by ldzielak
Johan,
I'm Stacking with a TST, I can set the max timing the TST will add on top of my Predator. I'm running a 7130. I'm experimenting with the stacker tunes and settings on the TST, any info on timing would be great.
Lee
2005 CTD 3500 SLT 4x4 QCSB, Patriot Blue / Silver, aFe Stage2, MBRP Exhaust, HTT 62/13SS, Diablo Predator & TST Stacked, Isspro guages, Full DTT 48RE w/ Billet Flex, Input & Output
help please
Posted: Wed Jun 13, 2007 10:27 pm
by samzram
how do i know which calid i have and do you have to return to stock setting b4 you download new programs
RE: help please
Posted: Fri Jun 22, 2007 10:16 am
by modified03
When you plug your programmer go to options i think and look for calid number and it will give you a number and thats it. Yeah i'm pretty sure you should go to your stock setting on your truck incase something messes up.
Posted: Mon Jul 23, 2007 4:23 pm
by skunkedtis
Do these not work for the new r29 firmware, I finally got a chance to update the firmware and then I want to load the performance stacker toon. I have it the programmer it shows the one I dled but when I click it to install it says it wont work then goes to the next screen saying do I want to install it? Any help would be appreciated.
This is the one I am trying to load http://www.diablosport.com/downloads/pr ... _stack.drd Also what doe the 05 12 15 20 and 25 before the xxx mean?
Tyler
Posted: Wed Jul 25, 2007 3:12 pm
by duallydave
the 05 12 15 are diferent calids.{not sure what a calid is}u need to find ur calid on ur truck and load the proper one.if ur calid is 12xxxxxx then u have the right one.check the baud rate and click on send tune to pred and it should go.
Posted: Wed Jul 25, 2007 3:15 pm
by duallydave
is looks like u are trying to load the pre r29 tunes.u need the post ones.the ones that have puff in them.they work with the r29.u should be good to go.
Posted: Wed Jul 25, 2007 9:07 pm
by skunkedtis
duallydave wrote:is looks like u are trying to load the pre r29 tunes.u need the post ones.the ones that have puff in them.they work with the r29.u should be good to go.
Thanks that helps a ton I am curious as to where I find out my calid number so I know which one I need to dl. I can get the toon in my programmer just not sure what one I need, I will play with it again tonight thank you for the help.
Tyler
