F-250 Standard Trans Tune
rob3277
Post by rob3277 »
I have a 99 F-250 with standard trans. I went in last year to buy a new tuner. But the standard options in the tuner did not allow for the standard trans. The guy could not download the new options. What I guess I what wanted to know is if I buy a unit online can I download a tune that will work with my standard trans. And I guess without a pyrometer And then how far after I add one. I have heard 1600 deg is as far as I want to push the exhaust temps. I tow and will be adding a pyrometer later, but need to put the money aside for that also.
sohfast94
RE: F-250 Standard Trans Tune
Post by sohfast94 »
The standard transmissions are supported... 1600 on the manifold is baout all you want to see. Just use the tow tune and you'll be fine.
Insert Clever comment here...
