new pedator owner ???????
i have a 05 srt-4. mods are AGP wg spike at 20 hold at 15-16, 3'' Catless DP, SRI, AGP upper hard pipe with turbo xs bov. Now i just installed the 93 tune and on my test drive my A/F was 12.7 at the top of 3rd and 13.0 at the top of 4th, knock was 5 and if inj pulse width is any help it was at 27. i know im goin lean. where can i get the maual on how to log a pull with the DSP or how can i adjust any of this, can i adj the 93 tune or do i make my own tune. just need a lil help thankx
RE: new pedator owner ???????
The perf93 tune is made for a stock car!! We need to sticky this info...
You need to turn the boost down and add fuel in those ranges. If your on stock injectors, then you need to boost around 18spike and hold 14-15.. adjust your wga so that it has no tension and then play with the boost function on the pred to get the desired boost. Dont let a/f get over a 12.2ish wot.. 12.0 is good, any leaner and then its questionable.
dont ever run the car WOT that lean! Get out of it or risk blowing it up...
Go into diagnostics and then click live data. follow the directions on the screen, its simple.
yes you can adjust the 93 tune, but try modifying your stock tune.. Play with both tunes.
thankx for the help ill give it a shot n let you know how i made out
when you hit modify stock tune it seems like it actually is modifying the 93 tune. any changes that are made under "modify stock tune" carry over when you modify the 93 tune before installing it.
it doesn't make sense that there are 2 different places to modify the tune.
