Just purchased a Predator U7135 with revision v9r09. Trying to get lastest revision downloaded.
Have a Jeep GC SRT8 and a PC with Windows Vista 32bit.
Down loaded the DS Downloader and the Windows Vista driver from your website.
When I plug in the Predator, the device software installation begins but then fails.
In the Control Panel, a new COM port is showing (COM7, 8 or 9) with an exclamation point. The DS down loader in Auto Connet mode is only looking for COM 1, 2 or 3.
My cable is a USB to serial with no name on it.
See attached screen shots.
Please advise on possible solutions.
Thanks.
Can't connect Predator to PC
- Predator.doc
- (206.5 KiB) Downloaded 304 times
RE: Can
go into your Windows device manager and set your usb cable to COM port 1, 2, 3, or 4, and set the baud rate to 115,200... then you'll be all set...
Re: RE: Can
Thanks ....will try that.06MonteSS wrote:go into your Windows device manager and set your usb cable to COM port 1, 2, 3, or 4, and set the baud rate to 115,200... then you'll be all set...
RE: Re: RE: Can
and make sure you have the usb drivers installed for your cable...
jbracefan1977
Re: RE: Can
my brother's been trying to do this for awhile without getting anywhere.. thanks .. Ill set him up with this06MonteSS wrote:go into your Windows device manager and set your usb cable to COM port 1, 2, 3, or 4, and set the baud rate to 115,200... then you'll be all set...
