u7193 help
5.3rat
u7193 help
Post by 5.3rat »
:? I have an older predator and am having trouble finding it with my computer. I have installed the driver for the usb-serial cable and tried all of the com ports. I am told that the version 2.10 is not internet updateable. But I should be able to download the gm03_07predator interface 108exe onto the ds. When I try to do this, the pc does not see the ds. I have also tried serial-serial cable and the unit is not found. Please help me with some info on how to perform this. Also another question. Motor='04 zO6, computer is from a '98camaro. I had the computer programmed for the proper pin assign. in the harness and the motor is running ok. I just want the capabilities of changing settings i.e. idle speed, tire size, etc. When I plug the ds into the pcm, it says vehicle not supported. I want to make sure that the u7193 is the ds that i need before I ship it to Diablo and have it updated. Help please!!!!!!!!
RE: u7193 help
The PC interface will not 'see' the Predator, you have to set up the correct com port so it can talk to it.
ohiobellboy
RE: u7193 help
Post by ohiobellboy »
Ok, Newbie here. I've got a U7193. The revisions says 2.04, I bought it used and unlocked from a guy a year ago and have had some success with it. I just recently got the serial-to-usb kit and have installed the drivers. I've got the power running to the Pred and connected to the pc. whenever I go to PC Communications I get "Xmodem timeout". need some help here.
OBB
edit note: mfg date is 09/02
serial number is 004130
04 Avy with no performance mods. U7193. Lots of little things to make it mine.
Re: RE: u7193 help
ohiobellboy wrote:Ok, Newbie here. I've got a U7193. The revisions says 2.04, I bought it used and unlocked from a guy a year ago and have had some success with it. I just recently got the serial-to-usb kit and have installed the drivers. I've got the power running to the Pred and connected to the pc. whenever I go to PC Communications I get "Xmodem timeout". need some help here.
OBB
That is an older tool and not internet updateable.
ohiobellboy
RE: Re: RE: u7193 help
can it be sent back in for an update? if so, how much? Does this mean it also does not have logging capabilities and cannont connect to the pc?
Yes, it would be $99 + shipping to send it in to be upgraded to the newer tool which includes logging and internet updates.
ohiobellboy
ok, that's what I thought.
OBB
just to clarify.... as there seems to be some confusion on this issue according to some PM's I'm receiving...
if you are just trying to import/export tune files, you CAN do that now, on the current revision you are on - no need to upgrade...
But, if you are trying to update it to the latest 9rxx revision so you can save data logs and do internet updates - no, you can NOT do that via the internet downloadable crom revision update files - you have to send it back to diablosport for hardware upgrade, as mike mentioned... Now, AFTER that hardware upgrade has been done, then YES, you will be able to download the crom files from the site and update your predator to a newer revision when it's released.
WhiteBuffalo
Re: RE: u7193 help
Post by WhiteBuffalo »
OBB
WAKE UP Mikel!!!!
He is not trying to update via internet!!!!! :lamer:
He wants to send you his tune via email so you can turn on his fans... :roll:
If your not careful your going to start a whole new Diablo bashing event on the AV sites!!
WB :twisted:
05 Avalanche LT Z71 5.3 4.10, Volant CAI, Volant Ram Air Scoop, Corvette 2nd & Sonnax Super Hold 4th gear servo, KYB MonoMax.
Re: RE: u7193 help
WhiteBuffalo wrote:
OBB
WAKE UP Mikel!!!!
WB :twisted:
Dude, it said nothing about that.
If this were inthe same thread where I had offered him a free customtune, it would have made sense right away, but I hope you understand that I reply to EVERY post on this forum,. and cant be expected to remember every screen name.
Posting this inthe original thread would have solved the problem.
Either way, nothing has changed, and my offer to do the tune still stands.
WhiteBuffalo
I know....he showed up here when he couldn't connect....
It is very confusing when you are dealing with things on several threads.
We'll get him straight!
ohiobellboy
Whoa guys,
First off to Mikel, I thank you for your offer and am not turning it down at this point. I appreciate everything you do to help us out here.
WB, I thank you also for trying to get answers for me while I was at work today.
Lew, Thanks for the help with the pc connection problem.
Here's what I've got going on with the connection.
I get an XMODEM Timeout when trying to mate up the pc to the pred. I've downloaded "GM03_07Predator_Interface_108" and cannot connect.
Monte, You said something about configuring some ports. I bought the cable from Summit and the one they sold me has the serial port on one end and the usb on the other. From what I've read I should still be able to communicate with the pc with this setup. After we get that accomplished from what I understand, I should be able to email a copy of the tune to MikeL and he can alter it to control the fans, Is this correct?
As far as the updates if I can just get the fans to come on I'll be a happy camper. I've had some success with the pred as far as performance and fuel mileage and would like to keep it as opposed to spending the money on HPT. Where I was confused at is the fact that I thought I would have to get the pred updated for it to even connect to the pc but that does not appear to be the case.
If we can get this thing talking to the pc, then all should be good. I can still use a copilot to do "poor mans logging" to keep an eye on things.
Monte, if you'll be available in a few hours I sure would appreciate the help with the connectivity problem.
I'm not upset about the problems I'm experiencing with the pc issue. I was just dissappointed that I thought I'd have to spend another chunk of money to be able to do what I need to. That doesn't seem to be the case. :D
did you install the usb cable drivers that came with it???
also, let me know if you have an instant messenger screenname... I have AIM, yahoo and MSN messengers, so I can do any of those....
if you do have one, send me a PM with your screenname...
that's faster when tryin to help people out, instead of having to check the forums every 10 minutes... hahaha..
ohiobellboy
Re: RE: Re: RE: u7193 help
ohiobellboy wrote:Whoa guys,
I may have the wrong drivers installed but I believe I used the ones that said windows and usb...
AIM screen name huh....I need to try to remember that one.
pm will be coming shortly
Thanks Monte
ohiobellboy
06MonteSS wrote:did you install the usb cable drivers that came with it???
LOL,,,hit the wrong quote button,,,Hey Monte,,see the above post and it will be yahoo messanger that I have.
Return to “General Support”
