TCM settings
goosemanx
TCM settings
Post by goosemanx »
U7193,V9r07
2005,GMC,Sierra,Nevada edition,4.8l
What are your recomendations on the three tm settings,on or off?
What does each setting control?
electrotyper
RE: TCM settings
Post by electrotyper »
TCM settings? What are those?? I have a U7191 and I have...
NO TCM SUPPORT! :normal:
RE: TCM settings
In trucks we generally recommend that you can turn the first 2 off, but leave the 3rd one on.
sickREDsierra
RE: TCM settings
Post by sickREDsierra »
agree. first two off, third one on. increase line pressure a little, increase shift speed. let it eat.
run it til it blows, build it better ;)
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
goosemanx
RE: TCM settings
Post by goosemanx »
Thanks guys,how much do you recomend increasing line pressure and shift speed to. I know absolutely nothing about this stuff.
But I like your way of thinking sickREDsierra
RE: TCM settings
yeah, that's why he's had to replace his engine and tranny already :lol: :lol:
vroom vroom!! :lol:
sickREDsierra
Re: RE: TCM settings
06MonteSS wrote:yeah, that's why he's had to replace his engine and tranny already :lol: :lol:
vroom vroom!! :lol:
aaaaahahahahahahahahaha :oops:
shit happens :(
they didnt make these trannies to hold any power. and a little 4.8, who needs that. LOL
HDJoe
RE: Re: RE: TCM settings
Post by HDJoe »
Why does my u7193 not have these options? My TM option is only 'On, off, or No change". The truck is an 03 2500HD 6.0. My version is also 9r07
your truck is an 03, so your tune/PCM probably doesn't have 3 individual settings like the 05's, since the PCM's and programming are different...
No, the old tools have 3 settings, and the new tools only have 1 as the first 2 are now 'off' in the tune.
hmmm.. then goosemax must be wrong about the settings he actually has in his predator - must just be reading the info here on the site about those 3 settings... cuz he has the same model and revision as HDJoe... so if HDJoe doesn't have all 3, then goosemax shouldn't have them either...
goosemanx
Post by goosemanx »
U7193,v9r06 has the three settings I mentioned
U7193,v9r07 has the settings you are talking about , on
off
no change
zz50
Post by zz50 »
mikel,
I have a 7193 9r07 in a 03 Sierra and from another post I read you may be able to make even more adjustments to trans shifting. I have a TransGo shift kit and the 1-2 shift is harsh and quick. OK when flat out but leaves a lot to be desired at part throttle. i have the setting all the way to soft and need more. Can you help? And what does "no change" mean if you have "on" & "off" choices.
HDJoe
Post by HDJoe »
So what is reccomended for these "none optioned" tunes? Turn off the TM altogether?
bookemdano
Re: RE: Re: RE: TCM settings
Post by bookemdano »
HDJoe wrote:So what is reccomended for these "none optioned" tunes? Turn off the TM altogether?
Turn off the TM altogether.......then ad a 150 shot of nitrous, and
you'll be set....J/K..... 8)
