Estimated HP increase?
Posted: Mon Mar 30, 2009 11:21 pm
by Bdogg
What is the estimated Horsepower gain for a 2009 Dodge Challenger RT...5.7L Manual Trans...Using the 93 Octane performance CAI tune?
RE: Estimated HP increase?
Posted: Mon Mar 30, 2009 11:55 pm
by Mike_Levy
20hp 20ft/lbs
Posted: Tue Mar 31, 2009 7:06 pm
by Bdogg
Thanks Mike...What are some of the adjustments in this particular tune? Does it increase the rev limiter also?
Posted: Tue Mar 31, 2009 7:26 pm
by Mike_Levy
There is an option to advance the limiter, yes. You can also adjust the speed limiter, adjust for gears and tire sizes, and tweak the timing and fueling.
Posted: Tue Mar 31, 2009 10:52 pm
by Bdogg
so hypothetically, would I start be flashing a loaded 93 octane CAI tune, and then make adjustment to the rev limiter? (or any other specifics)or does this particular tune adjust it?
I see that the predetor has the option for customization, but not knowing too much about it I fear messing it up
I have just purchased the predator, and just trying to better understand the specifics, before connection....Seems like a great product...thanks for the feedback
Posted: Wed Apr 01, 2009 5:53 am
by Nazab
Yes you first download the 93 CAI tune and then change whatever you like ... don't touch customizing ... only quick adjusts... enjoy it.
Posted: Wed Apr 01, 2009 8:16 am
by johan
We already bump the rev limiter in the canned tunes so you can raise the shift points without having to adjust the rev limit.
Posted: Wed Apr 01, 2009 8:28 am
by Nazab
so in the 5.7L 91 CAI tune, at what RPM have you set the rev limiter as I think in mine I don't have any rev limiter !
Posted: Wed Apr 01, 2009 10:34 am
It would be at 6200 RPM
Posted: Thu Apr 02, 2009 8:25 pm
by Bdogg
with the manual transmission, what does increasing the shift points, as opposed to the canned increase of the rev limiter do?
Which one will enable the engine to not force you to shift @ stock setpoint?
What is the stock set @ in the 2009 RT Manual?
