Extreme RKL- missing after WOT
Posted: Wed Apr 08, 2009 11:03 pm
by Harter-built
I have the 7131 on my '07 5.9 6 sp. recently any time I run WOT I develop a "miss" in the engine and get the check engine light. I plug in the predator and no codes can be found. If I clear codes, It goes away and I can restart and run fine 'til I open it up at WOT. I am worried maybe I cracked an injector or did other damage. Any help would be appreciated. Mods include Pred/Puck(not on) S&B intake. 4" straight piped
Re: Extreme RKL- missing after WOT
Posted: Wed Apr 08, 2009 11:08 pm
by ropnjessi
Harter-built wrote:I have the 7131 on my '07 5.9 6 sp. recently any time I run WOT I develop a "miss" in the engine and get the check engine light. I plug in the predator and no codes can be found. If I clear codes, It goes away and I can restart and run fine 'til I open it up at WOT. I am worried maybe I cracked an injector or did other damage. Any help would be appreciated. Mods include Pred/Puck(not on) S&B intake. 4" straight piped
You need to cycle the key on and off 3 or 4 times consecutively and verify what code is being thrown, the code will display on the odometer. Then try and figure things out...
RE: Re: Extreme RKL- missing after WOT
Posted: Wed Apr 08, 2009 11:19 pm
by Harter-built
Thanks. I'll try it in the morning and see if a code displays.
Posted: Thu Apr 09, 2009 8:28 am
by johan
Update the Predator to the latest revision and you will be able to see what the code is.
Posted: Mon Apr 13, 2009 8:11 pm
by samzram
id guess on the rkl your running out of fuel and gettin a popping noise and miss from it.
Re: RE: Re: Extreme RKL- missing after WOT
Posted: Wed Apr 15, 2009 5:56 am
by ChrisMyers1
samzram wrote:id guess on the rkl your running out of fuel and gettin a popping noise and miss from it.
Exactly what i was thinking... i know i was... sounds like its time for an air dog or fass fuel system... the reason you probably lose the code is because the rail pressure if brought back up after you let off...
RE: Re: RE: Re: Extreme RKL- missing after WOT
Posted: Fri Apr 24, 2009 6:10 pm
by Harter-built
Thanks for the replies, But now it's worse. I un-installed my Pred since this is now happening on all settings and at different throttle positions. I've had it on stock for a few days now and the same thing happened while at cruising speed(65-70 mph). Started a bad "miss", lost all power and engine light came on. cycled the key and code 2146 came up. I used the pred to clear the code and fired it up. code came back along with no power almost immediately. Any more help would be great. Worried about taking it to the dealer since they will probably void my warranty.
Posted: Sat Apr 25, 2009 1:33 am
by ropnjessi
P2146 Fuel Group Injector 1 Supply Voltage Circ
Posted: Sat Apr 25, 2009 1:26 pm
by Harter-built
So is that a bad injector? I was told it might be the harness. it seems to happen mostly after I've been driving for awhile.
Posted: Sat Apr 25, 2009 3:46 pm
by kw5.9
I dont rember what my codes were at the time but I have had both injector harnesses replaced already and I have had 3 injectors replaced, i have had the predator almost 2yrs and and put 80,000mi on the truck and this was my only problems, but sounds like injectors dont like ur predator either...ha
Re: RE: Re: RE: Re: Extreme RKL- missing after WOT
Posted: Sat Apr 25, 2009 7:58 pm
by ropnjessi
[quote="Harter-built"]So is that a bad injector? I was told it might be the harness. it seems to happen mostly after I've been driving for awhile.[/quote
I'm no mechanic but you would think the harness would be easy enough to test first, then start looking at the actual injector, that code looks to me like its describing a wiring problem...
