what do kill the tranny
Posted: Sun Apr 12, 2009 2:02 pm
by blackmagic1
hi, i just want!!
the heat and slip who kill the tranny....
if i have the gauge temperature oil for my tranny, i can use the tune extreme on my cummins 5.9 2005, i m driving smooth with this tune !! bad idea or okay!!
RE: what do kill the tranny
Posted: Mon Apr 13, 2009 1:22 am
by RRAM
I did the same thing, it was not a problem. of course anytime you add power you add more stress on parts. If I tell you its fine and your tranny crashes then what. Its not like these trannys just blowup because of the tuner
Posted: Wed May 20, 2009 9:14 pm
by blackmagic1
okay! so the problem ,the heat could be dangerous and slip? so if the tranny has never heating and slipping,i could be kill my tranny ?
(my english became little by little better! i learn english)
Posted: Wed May 20, 2009 11:35 pm
by RRAM
If your tranny is not getting hot and your not running it hard to slip the tranny then I would say no your not hurting it anymore then with a stock tune. The damage will come when you are trying to acelerate really fast or pull heavy loads and pour the power to it. don't matter if you have a 1000hp if your only using 200 to drive around. Good luck with your english learning.
Posted: Thu May 21, 2009 8:40 pm
by blackmagic1
good! thank for greats info!
is hard for me ,english learning, because ,is not my first language,
salut et merci beaucoup!
Posted: Thu May 21, 2009 9:36 pm
by RRAM
are you in quebec? I just came back from Levis, and a bit in Quebec city. I am happy to say I had great tranlaters.
Posted: Sat May 23, 2009 4:59 pm
by blackmagic1
yes i from quebec montreal!
Posted: Sun May 24, 2009 10:24 pm
by janettyracing
Guys, I just want to help here, The Torque converter and the valve body calibration is set up for 600 lb torque, if you make 900 lb torque the transmisson will fail sooner or later, unless you upgrade the torque converter and valve body to 1000 lb. torque calibration.
I have been building diesel pickups since 1993,
www.jannettyracing.com
Ted.
