cant adjust boost percentage on srt-4, any ideas?
streetsteve
ok heres my mods,
fm enforcer 1 turbo
fm wastegate
diablosport
aem shortram
maxxfab 3 inch o2 housing
maxxfab 3 inch side exit with no cat
180 thermostat
i have adjusted the wastegate and the parameters to get 15psi all through the rpm range but at 4000 rpm it shoots up to 19-20psi i have lowered the boost 40 percent between 4000-5000 rpm and wont make a difference, my current revision is 9r16, any ideas, any info is greatly appreciated oh yea the car is a 2005
fm enforcer 1 turbo
fm wastegate
diablosport
aem shortram
180 thermostat
streetsteve
Can you post a copy of your current tune file?
maybe a log too?
maybe a log too?
Yes. We need something to make a file from.
streetsteve
here is last tune written
here is the last tune written, some parameters are changed, all boost rpm ranges are lowered especially between 4000 to 5000 rpm it's lowered 40 percent and no change still hits 20 psi between that range
- 05029832AE_custom.drg
- it has wot fuel adjusted and has cooling fan times changed and boost percentage has been changed, lowered boost 40 percent at 4000-5000 rpm and no change
- (3.25 KiB) Downloaded 105 times
streetsteve
RE: here is last tune written
will i load the new tune into the diablo like getting a custom tune or will i remove 93 octane from the diablo and replace it with a new one
streetsteve
does the wastegate duty cycle need to be changed because i have the fm?
streetsteve
were you guys able to find any problems with the tune
Johan has been busy, has not had a chance to look yet.
streetsteve
no prob just dont forget about me, thanks
streetsteve
any word bychance yet? not trying to be a pester would just llike to drive it this weekend
streetsteve
any luck with it yet
streetsteve
has johan had a chance to look at it yet?
