Installed catless mids and new H-pipe, how does it look?
rnoswal
Post by rnoswal »
u7191
v.8r09
2005, Pontiac GTO
I just installed the catless mid pipes, and had an X-pipe but took it out and replaced it with the H-pipe. I have a set of Gibson rear mufflers. Now I took a data run and here it is. I would like your opinion about the numbers and would like to know how to turn off the rear o2 sensors please.
A much more raspy note without the cats. I may put the stock rear mufflers back on just to see how that sounds.
Russ
RE: Installed catless mids and new H-pipe, how does it look?
log looks good man..
ltft's are good at 0.2 and -1.98...
you're all set...
as for the O2's, are you getting thrown codes??? a CEL??? what are the codes you're getting?
rnoswal
Post by rnoswal »
Well actually, no codes right now. I seem to remember being able to get to the part in the programmer that tunes the cat temps to the point of taking them out of the system, but can't remember where now! So, when I do get a code I will let you know. Thanks for the thumbs up though.
Russ
